Chambered
Old May 5, 2008 | 07:40 AM
Gm4Ever89's Avatar
Car: 1989 Firebird Formula
Engine: 5.7
Transmission: Auto w/od
Axle/Gears: Stock
Chambered
I was wondering if there were any benefits to having chambered mufflers... Currently i have a flowmaster 3" exhaust from cat-back. and it sounds great but its just not loud enough. i still am looking for a set of headers. i know that will help. but i want loud... any suggestions?
Old May 5, 2008 | 08:52 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Re: Chambered
A flowmaster is a chambered muffler....
But if you want loud, I heard that Dynomax is the way to go.
Old May 7, 2008 | 07:49 PM
Gm4Ever89's Avatar
Engine: 5.7
Axle/Gears: Stock
Re: Chambered
Well being the car freak i am.. i hate myself for not knowing that. i guess ill just have to buy some headers to make this thing louder...
Old May 8, 2008 | 02:16 AM
IROCZTWENTYGR8's Avatar
Administrator
Car: Red 87 IROC-Z28 T-Top
Engine: 5.7 Tuned Port Injection
Transmission: 700R4 Auto
Axle/Gears: BW 9-Bolt 3.27
Re: Chambered
A high-flow converter and headers.
Old May 8, 2008 | 02:18 AM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Re: Chambered
Try some single chamber Delta Force Flowmasters. Thats what I have and i love them, both of them...
Old May 8, 2008 | 03:21 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: Chambered
I think he was referring to a powerstick chambered muffler. Which is a VAST improvement over a FLOWCRAPPER anyday. These flow VERY close to straight pipe numbers and sound incredible. Nice rumble at idle, NO drone, and speak very loudly when on the gas hard. These are real chambered mufflers like the oldschool muscle cars ran.
Old May 8, 2008 | 10:56 PM
82Five-O's Avatar
Car: 82 Sport coupe
Re: Chambered
OOOOhhhhh!... those kind of chambered mufflers. Well i feel dumb... but technically i wasn't wrong.
Old May 10, 2008 | 12:24 AM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Chambered
Dynomax are pretty much the quiestest aftermarket exhaust there is.
I've got an exhaust similar to what Mr Brooks posted. This is what stock manifolds, stock Y-pipe, high flow cat, and the catback sounds like.
http://smg.photobucket.com/albums/v2...t=MOV00624.flv
http://smg.photobucket.com/albums/v2...t=MOV00625.flv
http://smg.photobucket.com/albums/v2...t=MOV00626.flv
Yep. The 69 Camaros had that as an option if memory serves me correct. They have no drone at all. Zero. An aggresive but not obnoxious idle. I prefer to think of it as a tuned sound rather than a loud sound. And once you get around 3500 RPM, the trumpets sing.
I used to have no cat and a Flowmaster American Thunder.....I swapped to a high flow cat with the GMMG. It was still louder even with the cat (and Flowmasters aren't known for being quiet). But the sound improvement was night and day.
Last edited by Reid Fleming; May 10, 2008 at 12:27 AM. Reason: Automerged Doublepost
Old May 10, 2008 | 12:34 AM
Car: 1989 GTA
Re: Chambered
From an old thread of mine.
Stock manifolds and Y-pipe, no cat, Flowmaster American Thunder.
Idle 72 dB
70 mph 80 dB
WOT 88 dB
Idle is a cold start inside the garage. 70 mph is in O/D. WOT is measured at 5000 RPM under load. "A" weighted dB scale used. All are done inside the car with the windows closed, radio off, A/C set to OFF.
Stock manifolds and Y-pipe, Catco cat, GMMG with oval tips.
Idle 73 dB
70 mph 78-80 dB
WOT 90 dB
A bit louder at idle. Hard to get a good reading on the highway as the second you lift your foot off the gas it's ultra quiet. The Flowmaster was loud all the time on the highway. The WOT figure is misleading. Although 2 dB doesn't sound like much, consider that with the GMMG I'm getting 88 dB at 4000 RPM (the same as the Flowmaster at 5000 RPM)
Old May 10, 2008 | 07:30 AM
Administrator
Re: Chambered
I don't know, I've heard it all and for single exhaust I still think a crossflow or single outlet muffler sounds best and the chambered ones have an odd sound to them that's difficult to describe. The 1st Gens that had those were true dual with four of those mufflers (two on each side) on a big cammed, high compression, solid lifter 302 Z28.
Old May 22, 2008 | 07:39 PM
HotRodJackson's Avatar
Car: 1991 Pontiac Trans Am GTA
Transmission: 700 R4 slushbox
Axle/Gears: 2.73 Posi
Re: Chambered
Ok, that still sounds weak to me. I love the sound of SBC's hooked to open headers, with just enough piping to get the exhaust away from the spark plug wires or anything else flammable, that is, unless I have to make a quick, silent getaway from a women's place....
tyeo098
Nov 30, 2015 06:27 PM
92camaro350cci
Oct 14, 2015 09:29 AM
BBSDesigns
Sep 22, 2015 03:08 PM
formula_novice
Sep 5, 2015 03:58 AM
