Gasket for flanged cat...can't seem to find the proper one
Old Jun 11, 2008 | 11:07 PM
Ozz1967's Avatar
Car: 1984 Trans Am
Engine: LS1383 in work
Transmission: Magnum F - to be installed
Hey guys,
The search seems to be down at the moment. I'm looking for the exhaust gasket that goes down on the cat where it bolts to the Y-pipe. I've got an 84 T/A with the single exhaust. My current connection is the 4-bolt flange. None of the part stores seem to be carrying what I need unless I"m looking for the wrong part. Does anyone know which gasket I need?
Old Jun 11, 2008 | 11:21 PM
Guro 305's Avatar
Car: 1986 Pontiac Firebird S/E
Engine: 305 carb'd V8
Transmission: 4-speed auto
Axle/Gears: Stock
Re: Gasket for flanged cat...can't seem to find the proper one
Didn't know there was a gasket between the cat and the intermediate pipe. I thought it was designed with the ball and flange for this same purpose.
Old Jun 11, 2008 | 11:28 PM
Guro 305's Avatar
Axle/Gears: Stock
Ah wait! You have an 84. I think those didn't have the ball and flange and/or slip fits correct?
The y-pipe, cat' and intermediate all bolt on. I looked up the part no.s on Maremont's website for ya and it says that there is no gasket required. I remember doing this to another car I had before and I ended up just making my own gaskets out of a role of DIY gasket paper from Advance Auto.
Old Jun 12, 2008 | 06:53 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
IIRC, a gasket came with the four-bolt cat I once purchased.
JamesC
Old Jun 12, 2008 | 07:27 AM
Ozz1967's Avatar
Car: 1984 Trans Am
JamesC
There was one on there when I pulled the Y-pipe off...only problem is it came apart and practically disintigrated as I pulled the pipes apart. Looks like I'll have to cut my own I guess. No biggie, was just hoping someone knew a part number for the actual correct gasket.
Old Jun 12, 2008 | 04:35 PM
Guro 305's Avatar
Axle/Gears: Stock
Maybe! Mine is different since it has the ball and flange joint.
Old Jun 13, 2008 | 06:39 AM
JamesC's Avatar
The four-bolt is generally found on the L69.
JamesC
Old Jun 16, 2008 | 10:26 PM
vasquezmrysvll's Avatar
Car: 1985 California Iroc
Engine: HSR ZZ4 0411 swapped
Axle/Gears: 3.23 posi
i have the 4 bolt flang on my 85 iroc tpi origional exhaust. its listed as being the cat for the H.O. the 84,85,and 86 vette also share the same cat.i use DIY gasket material.
Old Jun 17, 2008 | 06:56 AM
JamesC's Avatar
I once order the vette cat, but it was shorter than the HO cat I eventually located and ordered. Based on that evidence, I don't believe they're interchangeable.
JamesC
Old Jun 17, 2008 | 09:50 AM
was wrong on vette years its 82-85. but the length and mounting is identical. check out the link http://cgi.ebay.com/ebaymotors/Easte...spagenameZWD1V
Old Jun 17, 2008 | 12:50 PM
Ozz1967's Avatar
Car: 1984 Trans Am
I'm not looking for the Cat itself, mine's fine, I'm looking for the gasket that goes on it.
Old Jun 17, 2008 | 03:26 PM
just make your own?
Old Jun 17, 2008 | 04:16 PM
JamesC's Avatar
I can't be sure of the year I ordered, though it was a four-bolt, but as I mentioned above it was a bit shorter, IIRC. Its oval mouth was smaller as well.
JamesC
Old Jun 17, 2008 | 04:44 PM
thats strange? maby the diffs vary from maker to maker? mine was exact?
Old Jun 19, 2008 | 10:49 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
He is correct, they were designed to be without a gasket. Even the 'vette used the same type.
GTAman
Mar 15, 2019 11:40 AM
Chiknhawk
Aug 23, 2015 05:54 PM
NinjaNife
Aug 23, 2015 11:49 AM
1988iroc350tpi
Aug 14, 2015 07:52 PM
