Exhaust heat shield
Old Jun 12, 2008 | 06:24 PM
TF34MECHH's Avatar
Car: 90 RS
Axle/Gears: 2.77
Exhaust heat shield
I have a passenger exhaust heat shield that is barely on and would like to remove it. I did a search and somene said it was held on with two screws and someone else said it was mounted with the exhaust manifold bolts. How is this installed? If I remove this how much of a heat increase am I looking at? It is a 89 Camaro Tune port.
Sean
Old Jun 18, 2008 | 12:47 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
Re: Exhaust heat shield
If the heatsheild is barely holding on you should just grab some tin snips or a dremel and cut of the parts that are hold it on. I remember when I pulled my manifolds the heatshield wrapped all around the manifold and wouldnt come off easy.
13sec83trans
Carburetors
22
Nov 28, 2015 09:26 PM
customblackbird
Oct 1, 2015 04:30 PM
85 Jimmy
Sep 30, 2015 07:56 AM
Stryker412
Sep 20, 2015 06:59 PM
ccop
Convertibles
Sep 14, 2015 04:13 PM
