383 HSR with 4inch Dynatech Split flow
Old Jun 15, 2008 | 08:22 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Well here is my nasty creation that i've been working on for last 7 months. FINALLLY STARTED!
FIRST start up this weekend but its leaking oil out the back of the manifold badly...so i gotta reseal that.
Specs are in the vid, but here's some more info. For those who havent been following the build, see pics in the sig to my webshots album
See garage link in sig for info on the build but rough specs i'll list
11:1 383 with AFR 195 Eliminators
230/245 custom grind hydraulic roller .603/.613 lift 109+1 LSA
Ported Stealth Ram
Hooker longtubes
into my own fabbed up y pipe. 3inch into 4inch flowmaster y collector
Dynatech split flow muffler mounted before axle
Dumped over the axle right now but will be dual exits like i had before
http://media.putfile.com/383-Stealth-Ram-Startup
VID does NOT do it justice... its very loud, very mean, and very erratic at the moment. I only have a base tune right now and it needs some work. IDLE rpm is set for 900 but in the vid its bouncing between 950-1150ish rpms with it mostly staying at 1050 or so but its alittle erratic
Old Jun 15, 2008 | 08:42 PM
pondriver's Avatar
Car: 1992 Camaro ZO3
Engine: 350 HSR
Axle/Gears: 9 bolt/3.70's
Re: 383 HSR with 4inch Dynatech Split flow
Very nice. I like.
Old Jun 15, 2008 | 09:03 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Dude your car is bad ***! I want to build my car like yours. Right now i am a sophmore in high school. So i was woundering how long it took you to make it a beast how it is now?
thanks
kevin
Old Jun 15, 2008 | 09:22 PM
skinny z's Avatar
Well done.
Old Jun 15, 2008 | 10:05 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
thanks
kevin
Bought it my senior year in highschool, basically had to work 2 years to get enough cash to get it. Then i worked alittle thru college and during the summers to get basic bolt ons done
summer 03 i had the car, then catback exhaust then suspension work. next year i replaced tranny and torque converter. had some gears installed sometime between then and 05.
car remained the same basically till 07 when i got the Stealth ram and new exhaust/drag rims/tuning stuff etc.
this build took me 7 months but i took my time and had to save money little bit at a time. Dec 07 i tore the L98 down and started collecting parts from jan 08 till last month and still getting parts Shortblock came in end of march/first of april and had it assembled by end of april but didnt get it in the car till may. Finally started today and its nowhere near 100% done
now that i got a "real" job aka one that i went to college for, i have some good money coming in now so i can really start to work on the car. If i had a job earlier, i would have had alot more done by now
Thanks for the props
Old Jun 16, 2008 | 08:49 AM
mw66nova's Avatar
Car: camaro sportcoupe
Engine: 7.0L
Transmission: G-Force GF5R
Axle/Gears: Moser 9"
justin it's looking and sounding great! i can't wait till i get me college job, lol!
Old Jun 16, 2008 | 11:39 AM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Very nice.
Old Jun 16, 2008 | 04:19 PM
Demon355's Avatar
Very nice dude! Sounds badass!
Old Jun 16, 2008 | 05:05 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Nicely Done....
Has a great tone. I bet when you get the tune better and drop your idle down that thing will be all chopped up and nasty sounding.
Old Jun 16, 2008 | 05:06 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
Thats what i cant wait to hear i think it will idle great at 900 rpms where i intend to settle it to. we'll see how low i can get it to work at. that 109 LSA does chop nicely
Old Jun 16, 2008 | 05:34 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
That is very good news about your car. Looks like you are making good progress and it sounds so good.
About the oil leak make sure there is enough sealant around the area where the old oil pressure sending switch used to go. Also the areas at the end of the head gasket.
Also down the road you will probably want to open up the neck of the air intake where the round part meets the flat area. There is a big restriction in that area on Camaro's.
Can't wait to see the dyno and track results.
Old Jun 16, 2008 | 09:34 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yep pulled the manifold today and resealed everything.. think i had a weak spot of rtv bead so i got it good this time with Right Stuff. worked great before and i hope it does good this time around.
I will see how the stock TPI box does with this car but i expect 10-20 hp loss thru that small hole. I plan on doing what TGO member DOC has done to his car...make a larger custom MAF sensor and recalibrate the tables. Hopefully it works. Thinking 3.5" MAF
Or else convert to 411 ecm from a LS1, the OBDII system. Looks interesting
But i'll drive it tomorrow if it doesnt leak oil anymore. good news for me cant wait. I'll try to tune the idle more and if it settles down i'll get more vids
Old Jun 16, 2008 | 10:29 PM
1bad91Z's Avatar
Car: Faster
Engine: Than
Transmission: You!
I looked through some of your pics. Please tell me you are going to ditch the stock injectors....
I recommend Ford SVO 30 lb. injectors for your motor.
I can also help with your tuning issues (PM me about that).
You are also going to need that motor to breath and might want to make something like this... https://www.thirdgen.org/forums/tpi/...pi-camaro.html
Looks and sounds nice by the way, good job!
Old Jun 17, 2008 | 06:14 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
what pics did you look at? lol i have RaceTronix 42 lb injectors now, but they do sorta look stock like
And yep, stock TPI air intake box should be restricting. I'd love to either make a custom CAI with larger MAF or do that box that you have came up with. We'll see what it does with the stock box, then i will go ahead and make something and see if i get any more power out of it. Should be a good comparison
Old Jun 17, 2008 | 06:47 PM
Car: 1989 GTA
Engine: 369 TPI
The local guys have found 7-8 horsepower with a modified airbox over the stock one on a chasis dyno. In your case with a well built 383 I would expect a much larger gain.
In fact with the computer simulation dynos the CFM intake of a 383 motor is what limits the horsepower in the upper rpm ranges. So if your are going to be spinning your motor well into the 6000 rpm range it will need all the cfm you can give it.
Old Jun 17, 2008 | 08:47 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well guys the split flow muffler idea is getting scrapped
fixed the oil leak today and took it on the street for a round the block trip and my god is it nasty. i dont think i got near 3000 rpms and i couldnt hear myself think...nor could the neighborhood.
NOW WHAT? what muffler to try? i'm thinkin dynomax ultraflo round.. 6inch packing round case, not the 4inch bullet
OR finish the tail pipes and put mufflers on each of those
Old Jun 17, 2008 | 09:50 PM
skinny z's Avatar
That's quite an endeavor isn't it?
Would you use an OEM configuration or try to set it like a 80's Vette with mufflers tucked up in rear rocker panels.
Old Jun 17, 2008 | 10:03 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well that idea is pretty much not taking off either
i wanted to tuck them up like vettes have them but i'm not seeing the room to do so.... ARGHH this car is killin me
I got the y pipe over the axle...so i'm ready to make 3inch dual exits like i had before. just thought i could stick mufflers there but i dont think so now
http://store.summitracing.com/partde...5&autoview=sku
thinkin of that..it wil fit where the dynatech is and has more packing so it should be abit quieter
Old Jun 18, 2008 | 12:14 AM
1bdbrd's Avatar
Car: 1991 Trans Am
What about running a regular catback with a cutout? Still good performance but will be quieter and easier to route.
Old Jun 18, 2008 | 12:17 AM
RevItUpZ28's Avatar
Car: '91 Camaro Z28
Engine: 383 Vortec HSR
Transmission: Pro-Built 700-R4;Vig 4000 stall
Axle/Gears: Moser M9 9" / 3.89
Sounds badass man, glad to hear the new motor is up and runnning!
Old Jun 18, 2008 | 03:36 AM
ZONES89RS's Avatar
Car: 86 TA, 91 B4C
Engine: 5.3, 4.8
Transmission: 4L80 4000, T56
Axle/Gears: 4.30 M12, 23.42 10 bolt
Man, i bet you have soe money in that thing. I wonder why it cams so fast? My cam is bigger than that and it is calmer. Might be because mine is carbed maybe with a 112 lsa?
Old Jun 18, 2008 | 08:08 AM
calebzman's Avatar
Car: '85 TA
Engine: 350 turbo
Axle/Gears: 3.70 posi 9bolt
I remember having that boat exhaust sound lol. What I used was a Magnaflow muffler where the stock cat would be. Made it a lot quieter & deeper tone. I also have a turbo and that makes it quiet too though, oh well. But, great job on the build and I'd love to check it out sometime.
Old Jun 18, 2008 | 01:59 PM
skinny z's Avatar
I've heard that a couple of bullet style mufflers will fit side by side in the OEM location. Have you considered that option?
Old Jun 18, 2008 | 02:00 PM
skinny z's Avatar
You love it!
Old Jun 18, 2008 | 04:01 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
i ordered the dynomax.. we'll see how it sounds this weekend. and yes i have some coin in this car Its not done yet tho
And it idles high because something is not quite right in the tune or i have a vacuum leak or something. during timing adjustments with the dizzy, when i had it all the way below 10 degreees base, the car idled choppy and lower rpm. sounded good. but i'll work on that
Now its time to do more breakin in
Old Jun 18, 2008 | 06:31 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
ok, took it for a little drive and break in session. Car feels like a absolute gorrilla!! Just mean!
I did the ring break in procedure that is recommended by GM performance parts as well as many other guys out there. Drive it hard early to help the rings set. By hard i mean do some pulls in a gear from light acceleration to medium hard acceleration adn let off in gear and let the engine slow itself down. vacuum helps oil the rings and helps them seal up against the cylinder walls i guess. Did a few pulls to 30mph or so then moved to 40, keeping rpms from 2500-4500 depending on what pull i was doing.
Anyway the car is breaking in and sounding better.. may have toned down a tad but its still very loud at part throttle and higher rpms. Idle isnt bad but any gas and its screaming.
Cant wait to try the other muffler this weekend
Old Jun 18, 2008 | 06:32 PM
IROCFAST's Avatar
sounds awesome.
Old Jun 18, 2008 | 07:23 PM
Car: 1989 GTA
Engine: 369 TPI
Ditto's to that.
Old Jun 18, 2008 | 09:20 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
kind of what it looks like.... gotta rehang the muffler as its angled downward too far in the back.. was tucked up nicely but welding i think warped the Y pipe downward so i gotta either bend it up or fab a piece to straighten it
still gotta bring the pipes out the back and get some tips like before
Old Jun 18, 2008 | 09:28 PM
Wishmaster's87IROC's Avatar
Car: 1987 1SICIROC.....1999 TransAm
Engine: 385 HSR.....LS1
Transmission: 700R4 with Midwest 3400 2.4str...M6
Axle/Gears: SLP Zexel Posi unit 3.42's...3.73's
ah? so you got 2 y-pipes? kinda like a borla setup?
Old Jun 18, 2008 | 09:45 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yes a 3inch pipe from each header going into a y pipe into a single 4 inch into muffler then over the axle into 4-into-dual-3's y pipe, basically the same y pipe that is in the front of the car but reversed direction so i can retain dual outlets like this, my old setup
Old Jun 18, 2008 | 11:13 PM
mw66nova's Avatar
Engine: 7.0L
justin, i would SERIOUSLY consider putting the pipes all the way out the back before pulling the muffler. that thing sounds badass and i would think that the tail pipes would tone it down a little bit, cause right now that sound is bouncing around and getting caught under the bumper cover, causing lots of interior noise.
Old Jun 19, 2008 | 06:29 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
well we'll see. The way i have it setup i could swap in a muffler in like 5 minutes its all in components so i can tear the exhaust off if need be.
i'll see what i can do this weekend or later tonight.. i may try to finish it up tonight since i got some 3inch pipe/bends laying around
but i tell you what, when you get this thing goin near 4000 rpms on the street under some throttle, it sounds sooo good. Most aggressive car i've heard in awhile :0
Old Jun 19, 2008 | 06:59 AM
1FastZ's Avatar
Car: 86 Iroc Z
Engine: 406
Transmission: 350 Turbo
Axle/Gears: 373
Sounds real good
Old Jun 19, 2008 | 03:21 PM
Demon355's Avatar
I've never heard about that break in procedure. How long do you do that for? I doubt I need to do that as I'm only changing the H/C/I on my motor. Sounds interesting though.
Old Jun 19, 2008 | 04:18 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
yeah its just for a new motor
http://paceperformance.com/index.asp...=Custom&ID=636
can read some of the advice here
https://www.thirdgen.org/forums/tech...tor-break.html
Old Jun 19, 2008 | 08:19 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
tell me you didnt remove the upper panhard bar
Old Jun 19, 2008 | 09:16 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
no its still there, you can see it cant you? besides i know ppl do that on 4th gens with no adverse effects, especially on more drag oriented cars mine is dual purpose
Old Jun 19, 2008 | 10:53 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
alright, now that weve seen and heard the open header vid, lets here it with the muffler on!
sounds wicked.
hows the resonance in the car?
Old Jun 20, 2008 | 06:04 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
its got a lot of interior noise at the low rpms, mainly between like 1500-2500 or so. when you mash on it over 3500 the outside volume has to be on the order of a demon spawn from hell haha, but its not loud anymore on the inside when on the throttle.
I would love to get rid of that resonance. I'll take out the CD player now as there is no way your gonna hear that.
Old Jun 20, 2008 | 04:17 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
, for some reason i looked at your pics and didnt see it, now i do, huh, guess i need more sleep
Old Jun 20, 2008 | 08:59 PM
  #42
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
update, redoing the exhaust. I'm gonna try the ultraflo by dynomax. I got the muffler yesterday and today i slipped it on and started the car up. Also fixed a vacuum leak so the idle is lower and more choppy now. not as loud too
but the ultraflo is definately abit quieter at idle. i didnt let it idle long for each muffler tested but i could definately tell the ultraflo is quieter than the split flow at idle. i gave abit of gas to the ultraflo and its back to being pretty loud, but hopefully the rest of the piping will tone that down as i only was running dumps at the end of the muffler for testing
I also ran open y pipe for comparison and it was much louder than either of the two mufflers so they do 'work'. its just that with any throttle, it gets loud quickly
Old Jun 20, 2008 | 09:30 PM
  #43
Car: 1989 GTA
Engine: 369 TPI
Looks like you are getting the "bugs" out of the car. My car is pretty quiet just cruising around and going down the hiway. However when you give it the gas it does roar.
Old Jun 20, 2008 | 09:42 PM
  #44
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
getting there. going to the car show tomorrow to see about hoods and possible tires if they are there
Old Jun 20, 2008 | 10:43 PM
  #45
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Axle/Gears: 4.71
which ultraflo model did you go with?
ive got a stock replacement crossflow model. quiet as a kitten.
now going down the interstate at 4200 rpms is a different story.
cruising, idling, its as quiet as you can get, and flows better than any muffler out there.
Old Jun 21, 2008 | 05:53 AM
  #46
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
its the 4inch in/out, 6" round case. 22 inches long i think it is
its alittle longer than the split flow but the main thing is that the ultraflo has larger holes on the inside of its glass wrapped tube core. that helps it be abit more quiet i think
Old Jun 21, 2008 | 11:36 AM
  #47
stroker_SS's Avatar
Car: 1984 Camaro Berlinetta
Engine: 355
Transmission: Th-350
Get those pipes out behind the back bumper a little, guaranteed to help hush it up a little.
Oh yeah sweet engine build to.
Old Jun 21, 2008 | 12:52 PM
  #48
88IROC350TPI's Avatar
Car: '89 IROC-Z
Engine: Canfield 195 headed 358ci
Transmission: TH350, Art Carr 9.5"
Axle/Gears: 3.92 Dana 44
sounds good... what kinda fuel are you running with such a high CR and smallish cam? your DCR must be through the roof.
Old Jun 21, 2008 | 08:05 PM
  #49
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
93 octane. DCR is 8.3 to 1. STR is 11 to 1. Cam is small on the intake but its got loads of lift so its gonna act abit bigger than specs show. its 286 advertised on intake when most 230 cams are 280-282
On my break in runs so far i have seen no knock retard and no counts so far. timing is fairly conservative i think but i havent really loaded the motor up yet
Old Jun 22, 2008 | 05:55 PM
  #50
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
took the car out today, the exhaust has been redone with the ultraflo muffler in place of the split flow.
Sounds abit quieter for sure at idle and part throttle. Stilll a touch louder than i wanted but much better than the split flow.
Sound at near WOT is the same. harder acceleration runs have about the same volume/tone so thats good.
Interior resonance has improved, its definately not as loud on the inside but still louder than i'd like. At cruise its fine, but on the throttle at 1400-2500 its loud inside the car with the windows down
Clearance improved but still hangs low. I tucked the rear up more and its given me some more cleance but the ultraflo has a fatter case at more like 7inchs instead of 5 of the split flow, so what i gained was partially lost by the fatter case. Still decent enough for me.
Idle is still abit erratic but abit better than before. its a touch lower, hovering between 875-1050 for the most part, desired is 950 then 900 after 176 degree coolant temps
May go work on the tail pipes now to get the tone exiting towards the rear of the car instead of over the axle.
The front end sits low since its on 25.4 inch skinnies. You can see about 1 inch to about 1.25 inch gap in fender from tire top. Once i get the new wheels/tires on, it should sit up another 1/2-5/8 inch atleast.
Rear is same way, its about 1.5-2 inch gap and is a 26.2 inch tire. new wheels/tires may sit 1/2 inch higher as well
