Header installation
Old Jun 29, 2008 | 03:00 PM
91 RS Drop Top's Avatar
Car: 91 RS Convertible
Engine: 350 TBI
Transmission: Stock Automatic-for now
Axle/Gears: 3.23 posi
Header installation
I started reading the sticky on installing the hooker long tubes. Is installing headers always this complicated? It talks about having to replace the starter, modify the oil cooler, weld in the O2 sensor, move wiring, etc. Thats probably more than I want to get into in an apartment parking lot with no garage to leave it in while it is tore apart.
It also sounds like there are some major expenses beisdes just buying the headers, like buying a mini starter.
I am completely new at this kind of stuff. Are shorty headers/other long tubes any easier/cheaper? Thanks.
Old Jun 29, 2008 | 03:38 PM
Simply-305's Avatar
Car: 1987 camaro RS/Z28 clone
Engine: 305 bored .030 over
Transmission: 700r4 slippin its way home
Axle/Gears: 9 bolt 3.43 gear
Re: Header installation
shorties are cheaper and 99.9% of the time direct bolt on.
that .1% is if you get the most garbage of garbage headers and they ****ed up the flange when they were welding but .. i hope you dont get a cheap pair...
anyway.
shorties are the easiest.
as they say in the write up. long tubes make a significant difference on a higher performance engine.
Old Jun 29, 2008 | 05:05 PM
Engine: 350 TBI
Anybody know of some long tubes that I can use without having to make modifications?
Old Jun 29, 2008 | 07:48 PM
brandoz28's Avatar
Car: 1987 IROC
Engine: 350 vortec
Transmission: TH350 3500 stall
Axle/Gears: 3.73 10 bolt grenade
Hedmans fit pretty well, but no longtube header install is a direct bolt in
Old Jun 29, 2008 | 08:14 PM
Engine: 350 TBI
ok. I guess I'll be going with shortys then. This is a first time, budget build and I'm trying to keep things uncomplicated.
Anybody got suggestions for a good "bang for your buck" short tube? Avoiding the garbage described above. I am also big on an absolute direct bolt in. I am short on time, workspace, available tools, experience and help so I realy want to avoid anything that will be a pain to fit.
Last edited by 91 RS Drop Top; Jun 29, 2008 at 08:19 PM. Reason: Automerged Doublepost
Old Jun 29, 2008 | 08:22 PM
91z 2 8's Avatar
Car: 04 Jetta
Engine: 1.8t AWP
Transmission: 5spd
hooker 2055s i have um not on yet but seams easy to do and got y pipe and headers for 449!!
Old Jul 2, 2008 | 12:34 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
That would be my recommendation as well, but they aren't a direct bolt-in to a stock LO3 exhaust.
But, then, anybody looking for performance shouldn't be leaving any of the stock exhaust in there, with the possible exception of a hanger or two.
Old Jul 2, 2008 | 05:51 PM
Engine: 350 TBI
I don't have an L03. I need to change my profile. I found out after buying the car that it has a 350 in it. I think it is one of the flat tappet truck motors based on the casting number. I can't see the engine suffix so over the holiday weekend I am going to pull the AC compressor off to try and see the numbers and figure out exactly what I have.
the original TBI and best I can tell everything else from the L03 is still on the engine. I don't even think they changed the computer or injectors but that is a separate issue. It looks like the stock L03 manifolds are still on the motor.
So when you say " wouldn't be a direct bolt on to a stock L03 exhaust, are you referring to the y-pipe?
I am gonna change the y-pipe as well, and get a cat back, but I will probably do the cat back separate because of the price. Ay problem with doing it that way?
Am I missing anything here about what I need to change to completely lose the POS factory exhaust as you suggest? Thanks
Old Jul 2, 2008 | 08:14 PM
Bigseth's Avatar
Car: 86 Iroc 383 carb, 97 T/A WS6
Hooker 2210s are really simple to install. I too read that they were such a a pain and require lots of work to fit. I put mine in with a motor swap but have had them in and out a few times since. The driver side drops in from the top and the passengers side slides up from the bottom with the starter removed. I used my stock starter, the only mod I did was a remote mounted solenoid. As for the o2 sensor, I don't have any buy my Mufflex y-pipe has a place for them. This is about the best exhaust system I've had on an F body, 2210 longtubes, mufflex y pipe and 4" catback, it sounds amazing. If you have the money this is definetaly the way to go. I did have a set of 2055's but I was going to have to open up the collectors (they neck down to 1.9") and have the air tubes cut off and welded shut, so I went for the 2210's and didnt have to modify a thing.
$.02
Seth
Old Jul 2, 2008 | 10:11 PM
Engine: 350 TBI
$.02
Seth
thanks for the input. I plan to lose the smog pump, just because I'm tired of fighting with all the clutter to do anything under the hood, so I don't want headers with all the air tubes. Do the Hookers have all the air pump crap on tehm?
Old Jul 2, 2008 | 10:40 PM
Bigseth's Avatar
The 2210 long tubes don't have any smog tubes. IMO they are the best longtube for the money, and with angle plug heads you can change all the plugs from the top. I will definitely use them on my next thirdgen build.
Seth
sweet_87_iroc
Sep 25, 2015 10:01 PM
Wesly_66
Aug 26, 2015 09:55 PM
mdtoren
Aug 23, 2015 12:52 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
