Problems installing Dyno Don Headers
Old Jul 11, 2008 | 08:21 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
Just began my installation. I chose the left side first. They hit the K-member and won't bolt up. I don't have to notch the K member do I?
Answer to common question-car has never been hit-period.
Engine mounts are original and appear to be in good shape.
I may change them with stock ones just to be sure.
Anyone else ever have this problem?
GW
Old Jul 11, 2008 | 08:55 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: Problems installing Dyno Don Headers
never heard of this problem your motor mounts must be absolutely destroyed for this to be happening. Every other post ive read about these headers is that they go in with little struggle.
Old Jul 11, 2008 | 09:01 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
mine went in easier than the old edelbrock tes's. It has to be your mounts
Old Jul 11, 2008 | 09:19 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Ditto's on the motor mounts. They may be sagging after all the years of use.
Old Jul 11, 2008 | 11:29 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
I'm replacing them all tonight, I'll let you know
Old Jul 12, 2008 | 08:12 AM
Fast92RS's Avatar
Car: 1992 Camaro RS
Engine: 383 SuperRam
Transmission: 4L60
Axle/Gears: 3:23 Posi
If you dont want to get a set of solid mounts use a set of poly mounts. They will hold up better.
Old Jul 13, 2008 | 07:37 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
The mounts were a huge job to get out. They are, as the gentleman said "destroyed". Amazing they did anything at all. They are crushed nearly 1/2" +/- a bit more, broke loose from attaching to the metal frame, rubber is laying over on it's side. Visually in the car I just could not tell, amazing. Transmission mount is collapsed a 1/4" as well.
GW
Old Jul 13, 2008 | 09:06 PM
Car: 1989 GTA
Engine: 369 TPI
Glad that you found the problem(s). Maybe the car will run a little smoother with all the new mounts.
Old Jul 24, 2008 | 10:23 AM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
I installed poly mounts and the headers went in no problem.
Old Aug 15, 2008 | 08:54 PM
GWW's Avatar
GWW
Car: 89 Iroc-Z
Engine: 5.7
As an update to this. New rubber mounts helped but the header still rubbed heavily. I tired poly after that and the #3 tube just touched. After a few PMs with the header builder it is apparent to me that amongst other things Chev couldn't build with much quality during this era the manufacturing tolerances for K members and their attachment points fluctuate enough to cause this. It's rare, he has seen it twice other than mine. Figures this kind of c..p seems to have a way to find me. I just tried to install my J&M camber plates while waiting for parts to finish the exhaust install and new out of the box the bearings are seized.
GW
1992rs/ss
Jan 31, 2025 05:10 PM
MustangBeater20
Oct 29, 2022 09:20 PM
1984HO
Mar 19, 2021 11:59 AM
Grant2k
Jul 10, 2018 04:01 PM
1992rs/ss
16
Jan 28, 2016 09:58 PM
