My exhaust is GONE...
Old Jul 18, 2008 | 08:22 PM
1986Sleeper's Avatar
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
I need some help I just got another Camaro its an 88 RS V8 with a 5 speed.
Its been awhile since ive gotten under a fbody, my last camaro was automatic, and that was about 2yrs ago.
Neways all i know is someone put a 3ft. tube onto the y pipe and called it a day. Nothing else and it sounds like crap.
My plans are to get a set of summit long tubes. I want to run tru duals because i already have 2 40 series mufflers.
I have a pipe bender at my shop, and welder at my disposal. But how do i need to go about this, has it been done, can it be done.
Are there anythings i should look out for when doing it?
Any info on tru duals on a 5 speed would be great.
Pictures of a set up would be the best.
thanks for the info
Ron
Old Jul 18, 2008 | 08:41 PM
Parasoth's Avatar
Car: 99 Z28 / 68 Skylark
Engine: LS1 / 455
Re: My exhaust is GONE...
Not trying to be mean but...
I bet if you just try "long tube dual pictures" you would get a lot of hits.
(P.S. Look at the very top thread of the exhaust forum also. )
Old Jul 18, 2008 | 09:11 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
seriously, the first sticky, a pic gallery....
and this fine thread
https://www.thirdgen.org/forums/exha...ts-x-pipe.html
summit doesnt have house brand LT headers.
Old Jul 18, 2008 | 09:34 PM
Car: 89 Camaro RS
Engine: 305 TBI
Transmission: TH350
Axle/Gears: Stock
my bad, wcich ever are those cheap lt's through summit
Old Jul 18, 2008 | 10:29 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
the uncoated headman long tubes are about 150bux, cheap as LT's go, the only problem, they dont clear the slave cylinder for the clutch, they have to be modified.
Old Jul 19, 2008 | 01:17 PM
tweakhat's Avatar
Car: 1986 Trans AM
Engine: LS1/T56
Axle/Gears: 3.83
get some shortys, or long tubes from hawks 3rd gen
zapr
Jul 27, 2018 06:03 PM
PurelyPMD
May 5, 2016 04:57 PM
86White_T/A305
Mar 6, 2016 01:48 PM
1992Z28!
Nov 19, 2015 07:33 AM
david068513
Sep 18, 2015 10:36 AM
