headers question
Car: 87 Trans Am
Engine: V8 305 TPI
headers question
since headers are fairly cheap I wanna put some in my TA, but I dont know much about them. are they easy to install myself? Where do they go in the engine? what are the best kind to get? any information I can get on em will help. thanks
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Re: headers question
They replace your exhaust manifolds. I personally like hooker headers. They can be installed by yourself but they will take some time to do.
Car: 87 Trans Am
Engine: V8 305 TPI
so basically what Ill have to do is take apart a good portion of the top of the engine, put the headers on the exhaust manifold then weld the headers to my exhaust system?
Car: 85 Iroc-Z
Take the exhaust manifolds off, then bolt the headers to your cylinder heads. Hooker sells their own y-pipes that bolt up to their headers.
Transmission: 4L80E/4L80E
Hooker 2055HKR are made for '86-'90 TPI single cat applications. They include a y-pipe (arguably the best production one available). They will bolt into the system (with a couple of minor modifications, explained in the installation instructions http://static.summitracing.com/globa...ok-2055hkr.pdf ).
They might not fit your definition of "fairly cheap", but spend any less, and you're going to pay for it one way or another.
Car: 87 Trans Am
Engine: V8 305 TPI
thanks five7kid. from reading the instructions it seems a bit much for a novice to be pulling out so many components of the engine and whatnot.
Well, what have you done? Changed oil? Changed spark plugs? Filled up the gas tank?
You have to start somewhere. While this isn't the best task to undertake in the apartment parking lot, it isn't something that can't be done with basic hand tools and jack stands/ramps. Having someone help who has some experience is always a bonus.
hectre13
Sep 8, 2015 03:38 PM
