PURPLE HORNIES
Old Jul 23, 2008 | 06:43 PM
LARKTIM's Avatar
Car: 1989 camaro
Engine: bad *** chevy
Transmission: a good one
PURPLE HORNIES
I will be running a 350 small block that i got with edelbrock on for the specs. it will be about 470 hp at motor. I have headers on it and wandering if purple hornie header mufflers were a good way to go or if there was something else that would sound better and perform better
Old Jul 25, 2008 | 07:19 AM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Transmission: G-Force t-5
Axle/Gears: 4.10 10bolt mini spool
Re: PURPLE HORNIES
I can only assume you have full length headers based on the question.
In any case, aside from there not being any room for header mufflers on these cars, those things will souund like a log truck coming down the road. You're only option with a full length header is custom. Whether that be dual or y-pipe is you're call. With 470ish hp you are within the limits of a 2.5inch dual setup(520ish is limit). Or a 2.5inch y into a 3.5 I-pipe then the muffler of you're choice. If you go y-pipe, I would avoid a cross-flow at all costs(they just sound like crap). I would rather have a single tail pipe(that's hidden mind you) that sounds good than two that don't. But that's just my opinion.
Old Jul 25, 2008 | 12:46 PM
LARKTIM's Avatar
Car: 1989 camaro
Re: PURPLE HORNIES
ok well im kinda uneducated on what i got, the car im getting from a cousin, the motor i have, the car now has 3" straight dual exhaust on it, i will be putting the headers on it, i know the headers are Hooker super comp, i was wanting to keep the dual exhaust and use the flowmaster super 44 mufflers but im not sure if everything will fit do to ground clearance so im guessing ill have to have custom exhaust done. and im not sure if i should take the exhaust to 2.5", and would i loose some performance by doing so.
Old Jul 25, 2008 | 10:05 PM
IROCJoyce's Avatar
Car: 1987 IROC
Engine: 350 Gm H.O
Transmission: 700r4 built
Axle/Gears: 3.42 Locker
Re: PURPLE HORNIES
Nothing compares to rumble of purple hornies and the ease of installation. 6 bolts and two hangers and nothing else. I hear an x pipe with turndown mufflers makes more horsepower though for the mid to upper.
Old Jul 26, 2008 | 12:18 PM
MrBrooks's Avatar
Car: '92 RS
Engine: 357ci
Re: PURPLE HORNIES
Ther is not room under a gen3camaro/firebird for headerpacks they will hit the sub frame.
Old Nov 13, 2011 | 09:52 PM
Verhagen82's Avatar
Car: 82 Firebird
Engine: Boosted LSX
Transmission: Built 4L60E
Axle/Gears: 4th Gen 3.42s
Re: PURPLE HORNIES
What about longtubes + s pipes (to clear the subframe/trans crossmember) + Purple Hornies?
Old Nov 14, 2011 | 04:37 PM
gmstrong's Avatar
Car: 95 9C1,99 Sierra,90Sierra,00 sierra
Engine: TBI350,LM7,LT1,Vortec 350
Transmission: 700r4,4L60e,4L60e,4L80e
Axle/Gears: 10 bolt,14bolt,3:42,3:73,3:08,3:73.
Re: PURPLE HORNIES
I had a purple hornie on my tbi350 i liked it way better then the thrush glasspack.
Hotrodboba400
Dec 10, 2019 07:07 PM
3rd gen money
Oct 11, 2019 09:57 PM
Elephantismo
Feb 13, 2019 12:51 AM
Cleotiz
Sep 16, 2015 08:02 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
