Idea for fitting dual exhaust in our single exhaust tunnel.
Now it would be nice if we could run two three inch pipes all the way back and not have that fear of speed bumps right? Well why not run the header collectors into a good 3" to 4" or 3.5" Y and run the Y into two ovaled 3" pieces of pipe. The Y would act like a crossover pipe and also help mate the two exhaust pieces. Which would now be about 4" wide and 5" tall or so, now run that down that narrow *** tunnel GM gave us and when you hit the back separate the pipes and run them to mufflers or just dump them.
Not my idea...Dad was a hotrodder too lmao.
Thoughts? Opinions?
Thoughts? Opinions?
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Re: Idea for fitting dual exhaust in our single exhaust tunnel.
Thoughts? Opinions?
Thoughts? Opinions?
-- Joe
Car: 1992 RS 6spd
Engine: Carbed 357c.i.
Transmission: Built T56
Axle/Gears: Soon to be Strange S60
Because he was throwing an idea out there. I think that was slightly un warranted as a response. Coulda just said something like, "in your application you don't need it, but yes that would work, or no it wouldn't work." Just sayin, as I have no opinion at at all on as to whether or not that would work. Don't know enough about my own exhaust yet lol.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
Car: 1992 RS 6spd
Not saying I don't agree with what you said about the "need" for it, but if he has some kind of viable idea, why shoot him down point blank? Hey man, your the mod not me so I'm guessing you know more about these cars than I do, but in the same respect people like me go to forums like this because there are people like you on them. Not to basically be told our idea isn't worth contemplating because you don't see it as "needed" Now as for me jacking his thread, I've said what I had to say, and I apologize for doing that here. Good luck with your idea man.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
although anesthes did not give you the answer you wanted, he makes a valid point. unless you are making more than 600 horsepower to the wheels you don't need dual 3" exhaust. a single 3" exhaust is is good for 300 rwhp even though it will support more than that. most n/a small blocks in these cars don't make anymore that 450 rwhp. so if you are set on running dual exhaust then 2.5" is more than adaquit.
even if your idea was to be done, is there a machine that could mandrel bend an oval 3" pipe? if it can only be press bent then a round 2.5" mandrel pipe would be better than an oval 3" press bent pipe anyway.
dual 2.5" over the axle is simple enough, i did it on my car, and i like it, and im sure its more than i need.
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
I've seen Lsx cars running true duals 3" over 3.5-4" singles and gaining power in the rpm range. its all in the muffler you run tho, they have to flow enough for the motor. most single 3.5" setups only flow enough to support 450-500 hp on motor which is near 400whp. 4inch covers most builds. dual 3's are alittle overkill for 400whp but helps if your over that
i know there are ppl running single 3" setups deep into the 11's but i think they are holding their combination back some. there is some to gain with a 3.5" or 4inch single. Maybe even true dual 3"
plus it does sound much better with proper mufflers
certainly wont hurt a 375-400whp car if you have alittle more flow, you dont want any restrictions as is. But there is more to just flow in exhaust design
As far as going into a y pipe and then into ovals, i dont think thats necessary. you can buy a small x pipe or mini h pipe to do the same thing in the tunnel location. you can fit dual 3" down the tunnel IF you work to tuck it up. Clearance is low but it will work. I stuffed my 6" case 4" in/out ultra flow in the tunnel area and clear good enough for a street car...its just my ypipe that doesnt clear since i have spohn crossmember and longtubes
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
For a deep 10 second track only car my opinion would be different. But we're talking street cars here.
-- Joe
Car: 89 Iroc-z
Transmission: TH400
yeah but the idea wasnt centered on a street car or race car, it just was thrown out there for any car.
i too have spent alot of hours under the car and do agree, there isnt much to do and his idea isnt the best, but there are ways to get it to work. true duals have been done and its possible but agreed, most cases wont need it
When i do the T56 swap with better crossmember for clearance i'll probly be converting to true duals since its easier to do with T56 and non spohn crossmember but we will see when that time comes. I like my setup but want more clearance
Car: 88 Formula
Engine: LB9
Axle/Gears: 3.45
Thoughts? Opinions?
Thoughts? Opinions?
http://www.boyceindustries.com/oval-...omponents.html
Lots of sizes of oval tubing and the price isn't too bad either. I think that for a lot of the combinations that people here have some oval section tubing could be a benefit even with conventional single pipe systems. A lot of the reason that many of these cars don't run so well is because the exhaust simply doesn't have enough volume to do the job without restricting the power output.
Anesthes- If you pulled 120mph with a single 3" system good for you, but if you had a bigger exhaust system you would have gone faster, and you're not the only person on here at that power level. FBD presented an original idea, and good "out of the box" thinking that could be useful to a lot of us even if "true duals" are a pet peeve of yours. Moderator or not, no need to be a ****. Exhaust improvements are still pretty cheap horsepower all things considered, especially on our cars where the exhaust is such a problem.
Car: '82 Z28
Car: 1992 RS 6spd
Now the creative juices are flowing lol. Do you have any idea why the single 3" was noticably more restrictive? Was it the way it was manufactured? The degree of the bends? Something had to make it be that way right? Or was it just that it was a single 3" as opposed to a dual 3".
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
Car: 89 Iroc-z
Transmission: TH400
were you boosted or sprayed on that setup? blown motors seem to not mind smaller exhausts. I know i've been told by a guy on this forum he saw little gain changing out his 3" single on his procharged setup making near 600whp. forget what he went to, but it didnt help as much as alot of ppl would have expected.
Car: '88 Formula
Engine: LC9
Axle/Gears: 3.89 9"
-- Joe
LT1Formula
20
Nov 14, 2015 12:02 AM
somebody woke up on the wrong side of the bed lmao.
