Y Pipe Question
Old Jul 28, 2008 | 03:20 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
Y Pipe Question
Im getting a set of hooker headers for my car and im wondering what I should do for a y-pipe. I was thinking about getting one made from an exhaust shop but I dont know what size I should make it ( 3 inch from each header into a 3 inch y-pipe or 2.5 inch from each header to 3 inch y pipe)? What have you guys that have custom made y pipes done? The car has a 305 TPI and im not sure if 3 inch from each header is a little too much.
Old Jul 28, 2008 | 03:37 PM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Re: Y Pipe Question
You don't mention which Hookers you're getting. The Hooker 2055's, a board favorite, come with one of the best Y pipes available. You might consider them.
JamesC
Old Jul 28, 2008 | 04:18 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Y Pipe Question
Im getting the Hooker 2460's. I heard that the y pipe for the 2460's is nice but the end of them is only 2.5 inches. Will hooker's y pipe for the 2460's still bolt up to the stock exhaust with it ending in 2.5 inches or will it take modifications?
Old Jul 28, 2008 | 08:14 PM
JamesC's Avatar
Re: Y Pipe Question
Originally Posted by 85Iroc-Z
IWill hooker's y pipe for the 2460's still bolt up to the stock exhaust with it ending in 2.5 inches or will it take modifications?
I know of no performance Y pipes that will mate with an OE manifold.
JamesC
Old Jul 28, 2008 | 08:46 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Y Pipe Question
I meant will the hooker y pipe bolt up to the exhaust from the cat back? Also what size should the pipes be from each header?
Old Jul 28, 2008 | 08:55 PM
skinny z's Avatar
Re: Y Pipe Question
If your application is on the mild side, the hooker y-pipe should be fine provided that the header collector and y-pipe are at least 2 1/2 inches.
My earliest combination used a Hedman short header with a Hedman y-pipe which bolted directly to an OEM location Flowmaster cat back exhaust.
Except for constant collector flange leaking, it still managed to help in getting a 13.4 second time slip.
Old Jul 28, 2008 | 10:15 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Y Pipe Question
So I should just have a pipe made then that is 2.5 from each header into a 3 inch y-pipe?
Old Jul 28, 2008 | 10:19 PM
GoodlookinRS's Avatar
Car: 1986 corvette Z51
Transmission: doug nash 4+3 speed
Axle/Gears: 3:42 posi
Re: Y Pipe Question
I am also going to be doing this in a few weeks with the headers and y-pipe. What can i exspect out of this? Will it make my car louder? Houw much hp will it give me 10hp?
thanks
kevin
Old Jul 29, 2008 | 03:06 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Re: Y Pipe Question
Any ideas as to what size since im probably buying the headers tonight and I would like to know what size reducers to buy?
Old Jul 29, 2008 | 06:29 PM
Re: Y Pipe Question
Hey what ever you decide tell me what you got if you would and tell me how you like it!
kevin
Frozer!!!
Jan 19, 2024 04:55 PM
87iroctheo
Dec 4, 2016 11:47 AM
hectre13
Sep 8, 2015 03:38 PM
lt1z350
Aug 28, 2015 05:57 AM
redmaroz
Aug 16, 2015 11:40 PM
