Dual to Single cat Prom change?
Old Sep 29, 2008 | 07:40 PM
crazyman3737's Avatar
Car: 1991 Trans Am GTA
Axle/Gears: Yukon 3.73 posi
So Ill start off with saying that the car is a 1991 T/A GTA with the l98.
It has the factory dual cats/ y-pipe but an aftermarket 3in cat back single exit.
I'm looking into finishing off the exhaust with shorty headers and a y-pipe.
Ive searched all over and I think I have come to the conclusion that the Hooker 2055 and y-pipe combo will flow the best but it is a single cat system.
I am wondering if it is possible to do this without throwing a CEL since I emissions here. I believe there must be a way to do it but I have searched and come up with nothing.
I would assume that the Prom just needs to be re-programmed but can anyone help me please?
Old Sep 30, 2008 | 01:52 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Dual to Single cat Prom change?
Search this Exhaust board for "Dyno Don headers" and look at the wonderful setup he sells for our cars.
Then send him (Dyno Don) a PM for more info.
Yes you can convert to single cat but you'll be giving up power if you do. 4 cylinders into two different cats is better than 8 cylinders into one cat.
Old Sep 30, 2008 | 04:17 PM
Ive heard a lot about him but does he sell a dual cat y-pipe as well?
The only reason I was going toward the 2055 is that Ive heard great things about their y-pipe but if he makes one then great.
Old Sep 30, 2008 | 08:57 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
Yes he does. I just left his shop and he had a car on the lift which had a set of his headers. It had dual cats, and Don was about to weld in the y-pipe when I left.
customblackbird
Aug 15, 2021 10:16 PM
Brinkkl2000
Aug 4, 2018 08:29 AM
onefreakz
May 14, 2018 12:15 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
gta power
Aug 13, 2015 06:15 AM
