Exhaust Fitment
Old Oct 12, 2008 | 07:48 PM
JustinZ28's Avatar
Car: 1985 z28
Engine: carb 5.3 turbonetics t78
Transmission: th400
Exhaust Fitment
Ok, so, i have an '85 z28, all stock, and was wanting to give it a little more, "American rumble" per say.
I was looking at this magnaflow kit http://www.hawksthirdgenparts.com/ca...ustsystem.aspx and was wondering if it would be just a direct fit on the stock system, or if i would need to upgrade the rest of the system with it.
Thanks.
Old Oct 13, 2008 | 12:17 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Welcome aboard thirdgen.org.
It's not a direct fit, because the cat outlet connection is different than yours. Otherwise, it is.
Old Oct 13, 2008 | 04:45 PM
JustinZ28's Avatar
Car: 1985 z28
Transmission: th400
Re: Exhaust Fitment
So, i would need to get a new cat as well?
Would something like this work?
http://www.jegs.com/i/Magnaflow/642/94015CA/10002/-1
Old Oct 13, 2008 | 05:29 PM
five7kid's Avatar
Both ends of the cat are different. What you linked is a "universal" cat, which would require modification on both ends to install. Plus, it's only 2.5".
Makes more sense to modify the cat-back to fit your existing cat.
By the way, what engine do you have? I know it's a 305, but is it carb or TPI? If carb, the standard LG4 (VIN code "H"), or L69 (VIN code "G")?
Old Oct 13, 2008 | 05:31 PM
JustinZ28's Avatar
Car: 1985 z28
Transmission: th400
Re: Exhaust Fitment
Carb, LG4.
So i could get the magnaflow kit, and modify it to fit my stock cat? How extensive would the modifications be?
Old Oct 13, 2008 | 11:04 PM
five7kid's Avatar
The "right" thing to do would be to do the whole exhaust with '86-'90 TPI single-cat application stuff. Hooker 2055HKR headers have a 3" outlet y-pipe, Catco 9118 cat, and it'll all bolt together (except the A.I.R. - the driver's side check valve fitting faces to the back instead of to the front like stock).
Since your car is an LG4, the universal cat you linked would actually be an upgrade. But, if all you want to do is the cat and exhaust, the above-mentioned Catco 9118 could be adapted to your stock y-pipe, and the cat and exhaust would bolt together. Then, if you wanted to do headers later, cut the stock y-pipe off of the cat, hook the headers up.
Old Oct 13, 2008 | 11:15 PM
JustinZ28's Avatar
Car: 1985 z28
Transmission: th400
Re: Exhaust Fitment
Ok, thanks alot for your help.
SO i could get the catco 9118, the magnaflow kit, and then just adapt the cat to my y-pipe?
As far as adapting it, would it just be some welding of an adapter pipe or what not?
Thanks.
Old Oct 14, 2008 | 12:11 AM
five7kid's Avatar
You got it.
z 28 jari
Sep 14, 2021 10:03 PM
Fronzizzle
Feb 9, 2017 09:31 AM
86White_T/A305
Mar 6, 2016 01:48 PM
Chad Speier
Sep 24, 2015 12:32 PM
86White_T/A305
Sep 21, 2015 05:28 PM
