Question about air pump on L98
Old Oct 13, 2008 | 09:58 PM
85z28LT1's Avatar
Car: 1985 Camaro Z/28
Engine: 5.7L 350TPI
Axle/Gears: stock 3:42 open
So I went to get my car inspected and it failed because this air pump was not hooked up, the mechanic says it usually puts air into the intake manifold or cat, (this is the pump on the passenger side bottom of the engine) But my car has a complete new exhaust with headers, 3inch pipe, magnaflow high flow cat and dual edlebrock exhaust. So could someone explain a little more about this pump and what it does? now the camaro had a stock 305 and this L98 was swapped into it, so I want to see what I could do and if this system even works with the car. Hope you can understand me.
Old Oct 13, 2008 | 10:02 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: Qestioan about air pump on L98
Air pump (aka smog pump) simply pumps air into your exhaust. Blows it into the exhaust manifolds and into the catalytic converter. The extra air helps burn the exhaust more completely by increasing oygen in the burn and thus raises the burn temperature as well.
Old Oct 13, 2008 | 10:31 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
so how do I connect this to my new exhaust system? or does it not need it? cause they said it wont pass without it, but I was thinking about seeing if they could just let it slide cause i would need to go back to stock, parts I dont have, to make it work
Old Oct 14, 2008 | 10:14 AM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
This thread may help you out
https://www.thirdgen.org/forums/faq-...injection.html
Old Oct 14, 2008 | 10:40 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
Originally Posted by krisb410
thanks thats exactly what i needed! I was just looking int he wrong part of the forum
Old Oct 14, 2008 | 10:56 AM
krisb410's Avatar
Sometimes the search feature comes in handy
Old Oct 14, 2008 | 12:39 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
if you noticed i had tried searching but was getting what I needed
Old Oct 14, 2008 | 12:56 PM
krisb410's Avatar
I assumed you ment "was NOT getting"
No, I did not notice anywhere in your previous posts. I only had the info you posted. Thats why I did one and found that thread.
Also, the search here is kinda sucky. Sometimes you get exactly what you need, sometimes you don't.
Old Oct 14, 2008 | 02:25 PM
85z28LT1's Avatar
Engine: 5.7L 350TPI
lol I do mean was not. but I am a member on other forums and know how strongly people advertise the search function, so you can count on me ot search :-P
Old Oct 15, 2008 | 10:24 AM
85z28LT1's Avatar
Engine: 5.7L 350TPI
so on an 85 camaro there is a metal tube that sits down by the headers on the passenger side, of the engine bay, it looks like it curves around behind the engine, but does it go to the cat? I need to re-hook this system and he said I dont have to do the manifolds since they arent there just to the cat, so i just want to run the pipe and put the belt on and take it right back off.
Old Oct 15, 2008 | 11:31 AM
krisb410's Avatar
Re: Question about air pump on L98
Not trying to be a smart a**, but did you follow the tube by the passenger header that curves around behind your engine?
Where does it go?
It should go from the converter connection in the pic above to the cat itself. But I dunno if the Magnaflow cat you have even has a provision for the tube to connect to.
Pics of your car would be helpful in this situation. I am afraid that you may get screwed, and have to replace some of your exhaust to pass inspection. You may get lucky, maybe your cat has the provision to connect to the tube that connects to the diverter valve. I hope so. Otherwise you may have to replace you cat with one that has the proper provisions you need.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
redmaroz
Aug 16, 2015 11:40 PM
mcquigg
Aug 13, 2015 02:26 PM
