i want an answer once and for all...
Old Oct 15, 2008 | 08:30 PM
RED_DRAGON_85's Avatar
Car: 85 Camaro IROC
Engine: 5.7 TPI
Transmission: 700-R4
Axle/Gears: open rear, 3.42 gears
once and for all, what are the best long tube headers for a third gen CAMARO.
my camaro has no A.I.R, therefore it has no need for air tubes.
i have no AC, no egr no anything.
my accessories are an alternator and power steering.
my motor is a 350 moderately built to "400 hp at the crank" as claimed by the previous owner.
i doubt very seriously that it makes 400 crank hp, but i think that 330-360 is reasonable.
i have a 700-R4
my priorities are:
1) ease of fit
2) ease of spark plug change
3) price
4) performance
5) longevity
now I've done search after search and every single thread seemed to end in your wrong im right cause you are a dumb redne**...
now if someone has a part number of a long tube header that meets my criteria, then thank you very much.
if not, then i guess leave this open until someone does.
Old Oct 15, 2008 | 08:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: i want an answer once and for all...
There's only a handful of long-tubes available, so it's not that difficult of a choice. Hedman 68460s probably meet more of your requirements than the others.
Old Oct 16, 2008 | 07:20 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
But the real problem is trying to get them up there. If ease of fitment is a huge concern, try a set of dyno dons shorty headers. Best ones out there. I have them on my car, and they were so much more easier to put in then the long tubes
Old Oct 16, 2008 | 06:04 PM
krisb410's Avatar
Car: 91 RS Camaro, 75 L82 Corvette
Engine: LO3, 383 Stroker
Transmission: 700R4, TH400
Axle/Gears: 4th gen 3.23 posi/LS1 discs, stock
Problem, everybody has different "priorities", that's why there is no single BEST long tube header.
Deal with it, find the one that best fits your priorities, and that is what you can consider the best.
Old Oct 16, 2008 | 07:15 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
Transmission: custom 700r
Axle/Gears: moser 9" 3.90
if your not trying to get max effort from the engine then get some shorties!!
if you do want max performance get some hooker 2210's best seat of the pants bolt on (an easy 20-30hp)
your clearance problems will be on the pass side, theres a brake line that likes to get in the way! and also you might have to grind a little on the control arm bracket and a weld on the k-member! not to hard and well worth it in my opinion!
Old Oct 16, 2008 | 08:22 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
cool, so one vote for hooker 2210
like i said, i have never bought headers before, and my budget wont let me buy a few different ones and see what i like best.
unfortunately, no manufacturer will say exactly what you have to modify to get them to fit.
and yes, i am adamant about long tube headers.
i already have shorties on the car and dont like them.
plus, they have air tubes and are rusted and look like poo.
any other opinions?
as for what i plan to do after the headers, i am thinking about running each one through a glasspack and dumping before the rear wheels.
yes, its a bit "r"-word but hey, thats what camaros are good at. lol
(please dont ban me, i was only kidding )
Old Oct 16, 2008 | 09:30 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
ok, so how about these
http://store.summitracing.com/partde...5&autoview=sku
hooker 2138
long tube headers, 3 bolt flange, 1-1/2 primaries, 2.5" collector.
seems about right to me.
any opinions?
Old Oct 16, 2008 | 09:42 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
hooker 2138
any opinions?
those have small 1 1/2 primaries and only 2.5in collectors, these are what you want. http://store.summitracing.com/partde...5&autoview=sku
Probably cheaper to get the without the coating but they will turn to rust in short order. It would be best to fit them first and then get them coated incase you need to dent a tube or two to gettem to fit how you want.
Last edited by 89RsPower!; Oct 16, 2008 at 09:44 PM. Reason: Automerged Doublepost
Old Oct 16, 2008 | 10:31 PM
Car: 85 Camaro IROC
Engine: 5.7 TPI
well i figured that the 2.5" collector would be fine considering that i will be running true duals.
as for the 1.5" primaries, i thought that smaller longer primaries helped generate torque by increasing scavenging.
yeah, it would be a restriction above 5000 rpms, but realistically, this is a street car and torque is king...
should i go with 1 5/8 primaries?
i dont want to go too big and take a hit on torque
Old Oct 16, 2008 | 11:40 PM
iroc.86's Avatar
Car: 86 iroc
Engine: 383HSR
get the 2210's the ones you have listed are fender well exit you dont want those! if you want to run 2.5" with 3" collectors just get the matching reducers
you can get them cheaper painted
cheesehomer
Dec 31, 2015 08:48 AM
HoosierinWA
Oct 7, 2015 10:15 AM
kkirch15
Sep 30, 2015 04:44 PM
92projectcamaro
Sep 29, 2015 07:07 PM
buckeyecelt
Sep 24, 2015 05:50 AM
