Ground clearance with hooker super comp???
Old Oct 18, 2008 | 08:29 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Should i consider mixing lowering springs with hooker super comp longtube headers? The streets suck in winnipeg but long tubes will allow a stout motor to breath... Im thinking 2'' from stock with some good shocks.
Old Oct 18, 2008 | 10:21 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Axle/Gears: 9" ford 35 spline axles
Re: Ground clearance with hooker super comp???
About 4" with eibach pro kit
Old Oct 18, 2008 | 10:31 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
Would this be an issue when driving in the city?
Old Oct 19, 2008 | 08:45 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
Mine havent hit the ground yet with this spring combo. They did when I had softer V6 springs on the front. They are the lowest point of my exhaust.
Old Oct 19, 2008 | 06:12 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Engine: 357 t88 turbo motor
Transmission: Powerglide
Axle/Gears: 3.55
i want to do a long tube too. but i want the front about 2" lower than stock. they look like 4x4s
Old Oct 19, 2008 | 06:55 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
This is the height mine is and I run long tubes with no problem
Old Oct 19, 2008 | 08:08 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
thats what i wanted to hear! lol (nice ride)
Old Oct 19, 2008 | 08:13 PM
MaNiAk86's Avatar
Car: 1983 trans am
Engine: Vortec 350 w/ a comp cam
Transmission: B&Mth350 2800holeshot
Axle/Gears: 10bolt 3.23's
i have hedman longtubes w true duals and the lowest part of my system isnt the collector but where it dips under the trans x-member... the collectors are up in the subframe and you cant even see em
Old Oct 19, 2008 | 08:55 PM
T/Atime's Avatar
Car: 91 GTA
Axle/Gears: 3:73
I doubt my car would even change much of the ride height if i were to lower it 2'' because the car should have dropped at least an 1'' from new. This is good news.
Old Oct 19, 2008 | 09:12 PM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
The hookers hang lower the the hedmans...I have one of the skulte T-56 crossmemeber. so the exhaust is higher at the crossmemeber.
Old Oct 21, 2008 | 09:13 PM
mattsv8_03's Avatar
Car: 89 Camaro rs.
Axle/Gears: 3.55
i have a sphon racing th 400 tranny mount and tq arm. does it have to drop for that or can i get arround it? the red camaro with the 2" drop looks just right. what springs are those? are they the sportline. and are they too stiff for drag racing. i like the v6 springs they transfer quick
Old Oct 22, 2008 | 06:37 AM
likeenz24's Avatar
Car: 87 Camaro
Engine: 406
It has eibach proline springs. I havent had it back to the track since I installed them. I use to have V6 springs on it like you, which work great for drag racing. Ive seen pics of exhaust on here where people routed exhaust around the spohn crossmember. I you run in under you will have ground clearance issues imo...
Hotrodboba400
Dec 10, 2019 07:07 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Glowsock
Sep 5, 2015 07:48 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
