HOK-2460HKR and matching HOK-16767HKR y pipe will not line up help!!
Old Oct 19, 2008 | 11:04 AM
Slayer31988's Avatar
I have a 1985 IROC-Z 305 tpi and I installed the headers without a problem then I put the car up to line up the Y pipe and it was off by at least a half inch. I called up summit where i got the headers and y pipe and they said that it should fit and they could not help me and told me to call Hooker on monday. I'm just wondering if anyone has had this issue before or has any ideas.
Thanks.
Old Oct 19, 2008 | 09:40 PM
notguilty_25's Avatar
Car: 89 camaro
Re: HOK-2460HKR and matching HOK-16767HKR y pipe will not line up help!!
i bought the 2460 headers and the ypipe for my 89 rs. it was pain in the *** the first time. couldnt quite get it to match up but i finally got it after an hour of cussing and throwin a fit. then i just made my buddy do it. lol. but the second time i put it up after my head swap much easier. install the bolts in the ypipe to the header collectors. just keep everything loose fitting. dont tightin them. then go ahead and start the bolts in the headers to the heads. u may need a small pry bar to give u some leverage to get the holes to match up. but that is what i did. went 10x faster. good luck. i hope this helped.
Old Oct 20, 2008 | 10:11 PM
The y pipe is off by at least an inch I don't think i could force it in without damaging something even with heat. I sent pictures to Hooker and I am calling tommorow morning I will let you know how it goes. Thanks for the imput
Old Oct 26, 2008 | 08:28 PM
Car: 89 camaro
wow, that is off. i would definately see if the could send another one. did u try to take the headers loose and start the collectors first? just start dont tightin. other than that yeah let me know whats up. good luck
Old Nov 15, 2008 | 11:14 PM
CHAMARO's Avatar
Car: 92 Camaro Z28
Engine: 383
Axle/Gears: 9"
I have the same problem!! the left side header is really close to the frame too. I was planning on using the prybar method or just cutting and rewelding the y pipe. what did you end up doing?
Old Mar 15, 2009 | 03:22 PM
They sent me another y pipe and it was the same thing. I ended up haveing to cut the y pipe and weld in a sleeve so i could extend it to line up with the headers. Welcome to bolt on
Old Feb 28, 2016 | 06:26 PM
Billgluckman's Avatar
Old thread bump, but has anyone else had this problem? Anyone who's had no issues?
Old Feb 28, 2016 | 06:52 PM
84TA327's Avatar
Car: 1984 Trans Am
Engine: .040 over 327, aluminium heads
Axle/Gears: 4:56s auburn posi, mosers
I have the same ones, the instructions tell you to start the header bolts but leave them loose, then bolt the collectors in, then snug up the headers. I did this and had no issues.
Old Feb 28, 2016 | 07:50 PM
Good deal
Orr89RocZ
Apr 25, 2016 08:28 AM
hectre13
Sep 8, 2015 03:38 PM
fasteddi
Sep 2, 2015 10:29 AM
Elliswon
Aug 10, 2015 12:33 PM
