exhaust ports
Old Oct 25, 2008 | 01:04 PM
skyhigh4by's Avatar
Car: 2004 GMC 2500HD
Engine: Duramax LLY
Transmission: Allison
exhaust ports
Kind of a stupid question but Im trying to figure out which header install to order and I cant decide if the exhaust ports on my 062 Vortec heads are round or oval. Help please
Old Oct 27, 2008 | 12:42 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: exhaust ports
Which headers are you looking at?
SBC exhaust ports are round. Some of the newer aftermarket heads are D-shaped and raised .100" higher than stock.
Old Oct 27, 2008 | 02:55 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Re: exhaust ports
This should help:
Old Oct 27, 2008 | 06:25 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
Re: exhaust ports
Just about any SBC headers will bolt up, but the Vortec plug placement prevents you from changing about half of your spark plugs unless the headers are designed for them, otherwise you have to remove your headers to change your spark plugs. Dyno Don is the only one I know of that makes headers for the Vortech plug locations.
TA
db057
Apr 28, 2019 07:45 AM
mrestrictrplate
Sep 21, 2015 11:24 AM
eustodp
Sep 20, 2015 05:09 PM
ericjon262
Sep 11, 2015 06:07 PM
hdis2002
Sep 8, 2015 02:52 PM
