Headers For A 91 Z28.
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
thanks for taking your time in reading my thread,
first of all i live in california, so yeah you know what that mean emission laws. does anyone knows what brand makes california legal headers, long tube, midd tube, or shortys.
thanks.
thanks.
Engine: 3.0L 2JZGE
Re: Headers For A 91 Z28.
yeah i did, but i couldnt find out wich company has for smog legal headers.
thanks.
thanks.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
You're right here in California. Send a PM to Dyno Don. He has his headers in stock for sale right now.
You can search this Exhaust forum for "Dyno Don headers" for the pics.
Also, only shorties are smog legal.
Car: 1991 Formula L98
Axle/Gears: 3.73:1
Transmission: 4L80E/4L80E
Tony, single or dual cat?
Single cat, I believe only Edelbrock makes emissions-legal. Dual cat, Edelbrock and Hedman - I'd recommend the Hedmans unless you go with Dyno Don.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Engine: 3.0L 2JZGE
yeah acording to my smog buddy that i have he told me you could have long tube headers alongest you have the cats and the egr's and the oxygen hooked up on the headers that i would be good but do you think he might be wrong though?
thanks.
thanks.
Last edited by DeathMetalTony; Nov 6, 2008 at 11:15 AM. Reason: Automerged Doublepost
Engine: 3.0L 2JZGE
for my set up for the exhaust i have magnaflow cat all my pipeing on the car 2 1/2 and straight to the back and once it goes over the axle i have another y pipe then i have to 1 chambler flow master with turndowns.
and acording to my frine he tells my have a bunch of backpressure and thats good for top end and also if i would go with a true dual set up like i was going to i would have bottom end but since these cars have a lot of bottom end so i would just leave it the way it is
but if you guys have any suggestions please feel free to respond.
thanks.
thanks.
Car: currently a 91 G92.
Engine: 305TPI
Transmission: Borg Warner WC 5 speed
thanks.
thanks.
Read the sticky in the top section of this forum about backpressure. 99% myth, and 100% undesirable.
EGR isn't hooked to the headers, but A.I.R. is. There are no C.A.R.B. certified long tubes available (stated the other way already by Kevin). Being in CA, C.A.R.B. certified should be important to you. You will need to mount the O2 sensor.
Don's 1 3/4" shorty headers and y-pipe, along with a good 3" or 3 1/2" single exhaust will flow great for most horsepower levels, and will bolt right in with no custom fabricating required like you would for dual exhaust. I have Don's headers, dual cats, 3.5" single exhaust and a Magnaflow muffler on my car.
Engine: 3.0L 2JZGE
cause i when and got 2.5 tubbing for my exhaust it felt like the perfect diamater for my 5.0 i wanted to go with 3 tubing but im not even pushing that much horsepower on my engine caus emy goal for my z is to try to get some top end cause our cars have a lot of bottom end i was thinking about throwing on a cam and later on getting my self a vortech supercharger so yeah let me know if you got some good info.
thanks.
thanks.
Transmission: Pro-built 700R4
redformula88
Oct 14, 2015 06:08 PM
Saxondale
Exterior Parts Wanted
Sep 16, 2015 06:32 AM
