after installing headers on an 88 iroc 5.7 tpi; engine starts but will not run
Old Nov 5, 2008 | 11:47 PM
g5g5g5's Avatar
Ok so the edlebrock headers are installed.
the car starts, but will not run.
the car cranks and fires but wont stay running.
*the starter motor was dissconnected to install the headers ( did i install the wires to the starter wrong?)
does anyone know about this problem of the 88 5.7 starting but wont run.
maybe theres a little something i need to connect?
3 days ago before the header swap, the car was turn key start and run.
now with headers on it cranks, fires and dies.
please help , ill be working on it all night and checking this board frequently. thanks.
Old Nov 6, 2008 | 12:42 AM
Michael91z28's Avatar
Car: 1991 Chevrolet Camaro Z28
Engine: 5.7L 350
Re: after installing headers on an 88 iroc 5.7 tpi; engine starts but will not run
I'm not sure but it sounds like it could be something to do with pressure, or the engine may need to be tuned now. Does it idle a little bit at least before it dies?
Old Nov 9, 2008 | 07:39 AM
Beach Blazer's Avatar
If it starts then it is not the starter. I would make sure that you have re installed the plug wires in the correct firing order.
Old Nov 9, 2008 | 01:29 PM
IROCThe5.7L's Avatar
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Installing headers is not going to throw the tune of so bad it won't start.
When I installed mine, it would start then die. I then realized I forgot to hookup some vacuum lines. Check and make sure they are still all connected. Also, checking the firing order isn't a bad idea as stated above.
Old Nov 9, 2008 | 03:35 PM
pearl_iroc's Avatar
Car: 1988 Iroc-Z 28 Camaro
Engine: LSX
Transmission: MN12
this may sound dumb, but did you re connect the 02 sensor, a guy i know installed headers on his tiberon and didnt put back the 02 and had the same problem
Old Nov 11, 2008 | 08:51 AM
Pocket's Avatar
Car: 91 Trans Am
O2 is not necessary to run
Azrael91966669
25
Jun 20, 2017 04:04 AM
Wade787b
Sep 29, 2015 01:15 PM
jharrison5
Aug 19, 2015 05:53 PM
mustangman65_79
Aug 11, 2015 03:17 PM
drathaar907
Aug 6, 2015 04:20 PM
