small resonator off of a dump? any suggestions?
Old Nov 7, 2008 | 08:51 PM
lambocamaro's Avatar
I have an 84 with a set of hooker shortys and their Y pipe. I eliminated the cat and substituted a cut out pipe. The cut out pipe has a race ready electronic flap on it to seal it off when i want to be quiet. This will push exhaust throught the stock muffler in rear. So what I need is a very small resinator or muffler to put on the open side of the cut out to give me some tone when I'm running open headers. Right now it kinda sounds like a 84 pick up The headers are hooked to a GM Performance 330 deluxe crate engine, 0 miles. thanks
Old Nov 9, 2008 | 07:22 AM
Re: small resinator off of a dump? any suggestions?
Ok I did some measuring and I can tell everyone that I can use mufler with a length of about 9" gurth of 6" max and my cut out has a 2.5" three bolt flange on it. Thanks for looking. Any suggestions will be not go unnoticed.
Old Nov 12, 2008 | 08:48 PM
Nobody?? Is this a bad idea? Stupid idea?
Old Nov 23, 2008 | 05:07 PM
I feel as though I should thank everyone in this community for all the thoughtfull and extremely helpfull advise. So...... thank you.
Old Nov 23, 2008 | 11:12 PM
myvmax1's Avatar
Car: 91RS, 91RS
Engine: 305TBI, 3.1MP
Transmission: WCT5, TH700
Huh, lack of posts.... interesting
Well, are you just wanting some kind of muffler on there? My single chamber FLO's are small, have the flomaster tone (much louder!!!!) and are said to enhance scavenging. Flomaster also has these straight style(outlaw I believe) that employ internal rings.
There are a ton of compact mufflers. Dynomax bullets are another popular choice, as well as split flow. It's really up to you in what you want, or what you want to spend.
I will ask though, is your car tuned to run a cut out? Or are you just looking to be loud from time to time? Either way is just fine, your car is your individualtiy. What I'm getting at is, some cars actually lose bottom end power by the lack of back pressure.
Max,
Old Nov 24, 2008 | 02:02 AM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
There really isnt a lot of room under the car to put what you're asking for. Cut outs are designed to be wide open, not to have another muffler after them. But I bet if you search a Jegs or Summit catalog online you can find something small like you want.
However, remember its a violation of federal emissions laws to run without a cat on a street car in the United States. It doesnt matter if your area does tests or not, as its a federal law.
birdman_29
Jan 7, 2017 08:24 AM
Jorlain
Oct 8, 2015 01:57 AM
64goatman
Sep 9, 2015 01:09 PM
Jk_Under
Sep 8, 2015 08:13 AM
TBRays98
Sep 6, 2015 05:05 PM
