Is the Delco o2 i just purchased really a delco? anyway to tell?
Car: 89 Iroc
Engine: 5.7 TPI
Axle/Gears: 9 bolt Borg Warner Disk Brake Posi
so i just purchased and installed a 3 wire heated o2 sensor.
i bough it from rock auto.
it came in an ac-delco box. but is their any actual way to verify that it is a delco part.
it said made in japan on it and has 2 black and 1 purple or blue colored wire.
it had a 3 diget number on it aswell i can remember the number now.
seems to be working goood i would just like to see if i did get a delco part.
thanks. any info will help!
Car: 1990
Axle/Gears: stock
Re: Is the Delco o2 i just purchased really a delco? anyway to tell?
are there any numbers on it? generally a mfg will put its name on a product.
Car: 89 Iroc
Engine: 5.7 TPI
yea their was a 3 diget number that i can quite remember its allready installed. but it had made in japan on one side and 3 digit number on the other side.
looks like a quality sensor id just like to know if i got what was advertised
Car: 1985 Camaro Z-28
Engine: 385
Transmission: th700r4+Edge 2800 stall
Same boat at here too.I think it's denso sensor. https://www.thirdgen.org/forums/tpi/...tml?highlight=
I asked this from Rockauto when I noticed that sensor is made in japan.i got this answer:
Dear Jari xxxxxx
Thank you for your reply. This sensor should be the AC Delco part.
Thank you,
Karl
RockAuto Customer Service
Dear Jari xxxxxx
Thank you,
Karl
Car: 90 454SS
Engine: 454 TBI
Transmission: TH400
The one I picked up at the local dealer a couple of months ago was just as you described. So much for "Genuine GM Parts".
Car: '82 Recaro T/A, '71 Trans Am
Engine: 305CFI/455HO
Transmission: TH700R4/M22
Axle/Gears: 3.23/3.42
Delphi/AC Delco has outsourced many of their products in the last few years since they have gotten into financial problems. The battery division was sold off to Johnson Controls and spark plugs are now made by Honeywell Corp./Autolite. The replacement AC Delco O2 sensor I got for my '84 T/A looks an awful lot like a Bosch unit.
"Genuine GM Parts" is unfortunately not always "Genuine GM Parts" anymore.
Engine: 350 TBI W/all Ultimate TBI Mods
Transmission: 700R4 Stage 4
Axle/Gears: 9 Bolt 3.27
Honestly, the best 3-wire heated O2 sensor on the market in my opinion is made by Walker Products.
the ports are much larger thus, allowing more gases to flow thru getting a better reading. I have used Bosch (junk) and ACDelco (a little better than junk, lol). Once I came across Walker Products O2 sensor I will never go back.
Several guys that I know who are pros at tuning and burning chips have now switched to Walker Products. I can get them and ship them to anywhere in the U.S. for $55. That's the best deal I can find anywhere for the BEST product out there.
Walker manufacturers the sensors. Very high quality product and the specs are incredible.
Car: '91 TA vert
Engine: turboLSx
Yes, it is unfortunate that GM products are not what they used to be that is why I have been on the hunt for better quality products.
Car: '91 TA vert
Engine: turboLSx
Not really referring to NGK's plugs. Yes, they are excellent plugs. I am referring to sensors. ACDelco O2 sensors used to be excellent along with their coolant temp sensors, IAC valves, TPS etc. I have had more problems the past 2-3 years with those than any other product unfortunately!! I have heard this from numerous others as well.
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
You're right. It's hard to keep them in stock.
I guess I'll trade them in on their 1 year warranty and get NGK copper plugs. Though, I have read they run a little hot.
Car: 1987 Camaro LT
Never tried the copper NGK's but the platinums are working pretty well in my car.
snowflake
Sep 16, 2015 09:24 PM
[For Sale] 4" Spectre MAF Housing/LS7 MAF/Coupler
Ikes 91Z
LSX and LTX Parts
Sep 13, 2015 09:03 AM
NGK makes great plugs. I've never had issues with them.
