header gasket woes
Old Dec 20, 2008 | 05:24 PM
z28fever's Avatar
header gasket woes
I tried to fix my headers today, new gaskets because it sounds like an old beat up truck when im driving, (chug chug chug chug chug)... now for some reason, its bogging down and decided to die when i put it into reverse... i did break a wire but thats in a different thread, (wire between 1st and 2nd spark plug on driver side)
did i mess something up? when its idling it sounds great, no issues there, when driving its kinda boggy, really really sounds like an old beater (probably a different exhaust leak now), the bogging is a real issue, it wasnt doing it before, now im scared to run to walmart.... please help!
Old Dec 20, 2008 | 07:56 PM
JohnZ28's Avatar
Car: 85 Z28
Engine: 383
Transmission: TH350
Axle/Gears: 3:73
Re: header gasket woes
Did you by any chance remove any of the plug wires to change the gaskets? If you did make sure you didn't mix any up, probably 5 and 7 if it still idles smooth.
Old Dec 20, 2008 | 09:13 PM
z28fever's Avatar
thanks!
Old Dec 21, 2008 | 04:17 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
if your exhaust still leaks... get a dead soft aluminum header gasket... they will seal almost anything. jegs/summit sells them. also the single wire sensors on the drivers side up front is the engine temp sensor. im pretty sure its just for the gauge since thats the one i replaced for my stewart warner gauge, shouldnt affect driving. i second the spark plug wire swap!
z 28 jari
Sep 14, 2021 10:03 PM
Chad Speier
Sep 24, 2015 12:32 PM
bamaboy0323
Sep 12, 2015 07:14 PM
hdis2002
Sep 8, 2015 02:52 PM
dmtz956
LSX and LTX Parts
Sep 7, 2015 10:16 PM
