Catalytic
Car: 1985 Iroc, t-top
Engine: 5.0L HO L69
Transmission: Mt 5 speed
Axle/Gears: 3.73 Non Posi, Alum Drums
Re: Catalytic
My 85 is bolt on. Look under the car and you will be able to tell. Post a picture if you are unsure.
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Catalytic
I believe the front is welded to the y-pipe, and the back is bolted to the rest of the exhaust. Its best to take it to an exhaust shop and have them replace it with aftermarket one from Magnaflow, Catco, or Random Tech.
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
Re: Catalytic
FWIW, the cat in my '87 IROC is slip-on to the y-pipe, and bolt-on to the rest of the exhaust. I'm in the process of replacing the OEM cat.
If you have an air injection tube at the cat, it's pain to get this slip-on connection separated. I ended up cutting off the tube on the old cat with a Dremel and working the cut off end out of the air tube with a hammer and locking pliers. I'm seriously considering using a stainless steel compression union to connect the tube to the new cat in order to eliminate the slip fit for next time I need to do any exhaust work.
Also, if you go with a Catco replacement (P/N 9118) you'll need to get some extra nuts. Unlike the OEM cat where the holes in the flange for the pipe connection and the mount are threaded, Catco just has un-threaded thru holes. You might need longer bolts to accomodate the thicker Catco flange and extra thread length for the nuts.
Re: Catalytic
All TBI exhausts use the 2 1/4" cat and exhaust. You can replace it with another 2 1/4" cat, or get your muffler shop to upgrade the rest of your exhaust to 2 1/2" or 3" specs.
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Catalytic
Okay so I got my magnaflow cat in the mail today, when i matched the length of the new one to the old one there was a good 4-7 inch difference between them,the stock is longer. Should this be a problem when i take it to the exhaust shop tommorow? Or will it work?
Car: '87 IROC
Engine: LB9
Re: Catalytic
Well so okay I think the muffler shop can make an extension pipe easy enough to take up the missing length.
Car: 1985 CAMARO
Engine: 350 v8 CARB
Re: Catalytic
I just got my car back from the muffler shop, and I have to say im very satisfied with this cat converter. My car sounds a whole lot better especially when i start it.I had no clue that a converter could improve sound quality that much. But I do have one question, Why is my check engine light still coming on? could it be my timing?
Re: Catalytic
What code is it? We need that information before we can tell you what the problem is.
Car: 88 Camaro
Engine: L98 350
Re: Catalytic
First guess would be the shop unplugged the O2 sensor while working on the exhaust and forgot to plug it back in. Needs to be fixed soon if so, if the fuel mixture gets out of whack it will mess up the new cat.
[Sold] Dual cat y pipe
Eric-86sc
Sep 22, 2015 08:25 PM
