Which cat converter
Old Jan 19, 2009 | 08:54 PM
87whiteiroc's Avatar
Car: 87 Camaro
Engine: 5.7 350 TPI
Which cat converter
i am looking to replace my cat converter because mine is pretty messed up and i can not pass inspection. i wanted to know if anyone knows the highest flowing cat that will work with our cars. let me know which ones you use or the ones to stay away from. thanks
my car is a 350 v8 camaro and it has a stock exhaust
Last edited by 87whiteiroc; Jan 19, 2009 at 08:56 PM. Reason: Automerged Doublepost
Old Jan 19, 2009 | 11:24 PM
QuickStyle's Avatar
Car: 91 Z28
Engine: 383 SuperRam
Transmission: ProBuilt 700r4
Axle/Gears: G92 3.23
Re: Which cat converter
get the magna flow universal an exhaust shop weld it in. summit has them pretty cheap and probably $25 to install. stay away from catco, i've had bad luck with them and have heard others having the same problems, but some others have no problems with them. and drive with it installed for at least 100 miles before you attemp to get it smogged, if you have the sniffer test.
Old Jan 20, 2009 | 06:55 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
I've had several, no problems.
JamesC
Old Jan 20, 2009 | 12:32 PM
IROC216's Avatar
Car: 1985 CAMARO
Engine: 350 v8 CARB
I ordered the Magnaflow High Flow converter off of ebay on saturday, It should arrive tommorow, I paid $65 for it from a seller named rodpartsdirect
Old Jan 20, 2009 | 09:18 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Magnaflow, Catco, and Random Technology all make good "high-flow" cats.
Thank you for keeping your car smog-legal and keeping the cat on it.
92firebirdguy
Sep 1, 2016 07:53 AM
mud runner
Nov 2, 2015 07:30 PM
Camaro_383
Sep 11, 2015 11:28 PM
89fast5oh
Sep 8, 2015 09:55 AM
Stryker412
Sep 7, 2015 09:11 AM
