Weird sound from headers
Old Feb 5, 2009 | 03:21 PM
dijock94's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
i have a set off hooker shorty super comps and they're making a weird noise its loud and sounds kinda like an exhaust manifold leak is this normal?
Old Feb 5, 2009 | 03:46 PM
GuitarJunki17's Avatar
Car: 1990 IROCZ Camaro
Engine: 350 4bbl, 200cc Heads, 270hr Cam
Transmission: 700R4 w/ Trans-Go shift kit.
Axle/Gears: GM 10 bolt Posi
Re: Weird sound from headers
Not normal. Check for cracks in the tubes and that all the bolts are tight (and what's more, that they are even there to begin with). If your heads are clean enough, look for soot around the outside of the tubes on the heads. If you have an exhaust leak at the flange, it will leave this sooty residue on them, which is usually easy to spot on the top side of the flange. If this is the case, make sure your gasket didnt blow out. If this is a recurring problem (gaskets getting changed and leaks still present), then make sure your flange is actually flat and not warped, so that it gets good contact with the head.
Hope this helps.
Old Feb 8, 2009 | 11:53 PM
dijock94's Avatar
Car: 87 Iroc
Engine: 5.7 TPI
thanks for the advice but my motor is brand new and the heads are spotless, ill check to see if the header bolts came a bit loose. thanks again
Old Feb 19, 2009 | 01:44 PM
buttroq's Avatar
how loong have you had them? always a good idea to recheck the torgue on the manifold bolts after they get hot and cool down again. and then check them periodicly.
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Blue419
Sep 10, 2015 01:03 PM
Jlanz55
Sep 6, 2015 07:28 PM
Accerrito22
Sep 5, 2015 09:34 PM
willyjoejr
Sep 3, 2015 09:26 AM
