exhaust setup help
Old Feb 11, 2009 | 02:31 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
exhaust setup help
Got some money now in the bank, and looking possible for a new catback. I have a set of dyno don headers with his y pipe, along with a 3 inch catback with a 3 inch cutout right after the y pipe merges. I am debating if I should just leave it as is, or possible making it into a 3.5 inch or 4 inch exhaust. Would I notice much difference between a 3.5 or 4 inch as compared to my 3 inch with a cutout opened. If it won't make much difference, I think I would just leave it along and save myself 550 dollars. Any advice would be great.
My car on the dyno made 470 horse and 455 torque at the motor
Old Feb 11, 2009 | 03:04 PM
89formula350b2l's Avatar
Car: 92 Camaro
Engine: Dart SHP 406 HSR, LE heads
Transmission: Performabuilt Level 2, Vig 3200
Axle/Gears: S60 373
Re: exhaust setup help
I'm switching to 4" catback but i am also hooking up a 100 shot too. I have the xr276 cam and switching to a custom LE cam AND the 100 shot so...yeah imma need it.
Old Feb 11, 2009 | 04:21 PM
David 91RS/Z28's Avatar
That's really your call. What is your current catback? You can do the larger catback, but the muffler choices suck and really negate some of the gains from the larger system! I have the Mufflex 3.5" single outlet and use a Hooker Aerochamber. I had the Spintech at first. Went from 370 to 380rwhp by changing just the muffler. I still have a cutout and it's only worth 5rwhp now. Do not and I mean do not get the crossflow designed Mufflex system. Good luck!
Old Feb 11, 2009 | 05:38 PM
Car: 92 Camaro
Axle/Gears: S60 373
I wish they made Hooker Aerochamber in 4" I have to stick with Magnaflow
Old Feb 12, 2009 | 03:30 PM
Actually they do! With a little modification! The inlet and outlets of their mufflers have reducers. Basically use the #21509 muffler which have the 3.5" inlet/outlet and cut the reduced section off. Once these are cutoff you now have 4" inlets and outlets.
Old Feb 12, 2009 | 03:51 PM
PURPLEFORMULA's Avatar
Car: '89 Formula Firebird
Engine: LSX-451 / 705HP
Axle/Gears: Moser Ford 9" with 4.30
If your looking to upgrade, get true dual exhaust with either 2 1/4" or 2 1/2". I noticed a huge difference in power and torque and with having dual flow masters the sound is unmatched to any cat back system.
Eric
Old Feb 13, 2009 | 01:38 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
duals won't work very well with my shorties and that is to much work, when I would lose ground clearance that i cant afford to lose
Old Feb 13, 2009 | 01:29 PM
Car: 92 Camaro
Axle/Gears: S60 373
of course somebody tells me this AFTER i went ahead and bought 4" Magnaflow
Old Feb 13, 2009 | 01:57 PM
Car: 92 Camaro
Axle/Gears: S60 373
Eric
do you have dyno results or even better....timeslips to show the difference?
Old Mar 21, 2009 | 12:47 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
with the cutout closed I ran a best of 12.62 through the edelbrock 3 inch catback, with the cutout open I ran a 12.03. thats with a 1.59 60ft. I had bad tranny probs and I know I can get into the mid 11's
Hotrodboba400
Dec 10, 2019 07:07 PM
db057
Apr 28, 2019 07:45 AM
ericjon262
Sep 11, 2015 06:07 PM
snakeshooter
Sep 7, 2015 11:13 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
