Whats the best way to remove old headers?
Old Mar 20, 2009 | 01:54 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Transmission: 700R4 Auto
Axle/Gears: G92
I got a complete exhaust setup headers to the magnaflow 3 inch. But I am hesitant to start because even though driver side looks easy, how do I reach the bolts on the pass side header? Whats the best easiest way to do it? Also , should I use WD40 to unfreeze the bolts or are they easy to come off? Thanks!!!
Old Mar 20, 2009 | 02:11 PM
Ca[maro]88's Avatar
Car: 1988 Camaro Sport Coupe
Engine: 5.0 305 Carb'd
Re: Whats the best way to remove old headers?
always use some sort of lubricant. 3-36 wd-40 and my header bolts were 3/8 head so i just used a small 3/8 wrench. couldnt get a socket on it. it took forever lol.
Old Mar 20, 2009 | 02:18 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
So u just went for it :-) Cool, I am afraid I wouldnt be able to reach the bolts on the pass side. Did you remove the AIR first? How about the heater hoses?
Old Mar 20, 2009 | 02:32 PM
Ca[maro]88's Avatar
i just took the heater hoses loose. the air was a pain to get around but you can get it. getting the header out really sucks and be prepared to be a little "forceful" just be patient and try not to brake anything lol. just go for it, youll figure out how to get them off! good luck.
Old Mar 20, 2009 | 02:33 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
Thanks!!!
Old Mar 20, 2009 | 02:38 PM
Ca[maro]88's Avatar
no problem!
Old Mar 21, 2009 | 09:24 AM
theimpaler68's Avatar
Car: 86 T/A & 88 GTA
Engine: 305 LB9 TPI & 350 LO5 TPI
Transmission: Jasper 4L60 x2
Axle/Gears: 2.77/posi LSD & 2.73/posi LSD
i just did this last saturday. the pass side is easiest from underneath. i only had to disconnect the heater valve and pull out the dipstick. to make it easier for you on pass side also take out the spark plugs and starter. but sure jump right in. i had never done it before. only took the day to get them in. love it love it. do it yourselfers rock.
Old Mar 21, 2009 | 09:49 AM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
Tru Dat!! Anyone can pay a shop to do it for them.
Old Mar 21, 2009 | 10:55 AM
BlKnt18's Avatar
Car: 1989 Camaro Iroc-Z
Engine: 5.7 L98 Carb. Alum. Heads
Axle/Gears: 3.08 Limited Slip
or they about fall off. My old headers were leaking, and the bolts were very loose.
Old Mar 21, 2009 | 11:02 AM
that is why i bought stage8 locking header bolts with my headers so that i wont have that problem. reseaching also rocks that is what this site is for. research before you buy. research then buy once install once.
Old Mar 21, 2009 | 02:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
PB Blaster is a better choice than WD-40.
Old Mar 21, 2009 | 02:35 PM
BlKnt18's Avatar
The bolts that about fell off were from the previous owners work. I plan on going with percys gaskets and stage 8 locking bolts later. Need some more money...
Old Mar 24, 2009 | 08:43 PM
when you get a vehicle always inspect anything that looks replaced. just for your piece of mind.
Old Mar 24, 2009 | 09:54 PM
kallark's Avatar
Car: 1992 Z28
Engine: 350TPI
Axle/Gears: G92
Just finished putting mine in... Wasn't easy LOL couldn't get the pass side one in. I used regular bolts from Home Depot. Is that a really bad idea? I asked a mechanic I know, he told me it does not matter. Wanted to do everything myself too, but I can't put in the exhaust pipe (between mufler and cat) , car is not high enough. How did you do it? I have a new pipe and really dont want to cut it. Going to the shop tomorrow to get the car higher on a lift.
Also while removing old headers, I had to remove valve covers too. Anyone else had to do this? And yes I also removed spark plugs. I noticed that my dipstick tube rusted thru in the middle, is it tough to replace it?
Old Mar 24, 2009 | 10:03 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
there is a gun lube called break free. it is so fine a lube that it actually absorbes into the metal. you can spray it on and actually see it go in and the metal darkens like old wood when you put water on it.
go to the gun shop and get some. spray it on and wait a few hours then put some more on.
it will work better than anything else on the market.
Old Mar 24, 2009 | 10:06 PM
Car: 1990
Axle/Gears: stock
ca[maro] there was a guy on this board that made a wrench for those tight places, and specifically plugs.
he cut a complete notch into the socket, taking out about 1/5th so that the socket would fit over plug top but still fit over the bolt part. maybe something like that could help.
sort of like a box wrench with a rachet on it.
Old Mar 25, 2009 | 01:33 AM
Ca[maro]88's Avatar
my dad has made wrenches like that, cutting part of it so it would fit. its obviously a really good idea and it would take a lot less time if i had a ratchet lol.
hectre13
Sep 8, 2015 03:38 PM
formula_novice
Sep 5, 2015 03:58 AM
3rdgenparts
Aug 8, 2015 07:09 PM
mustangman65_79
Aug 7, 2015 09:55 PM
drathaar907
Aug 6, 2015 04:20 PM
