2055's plug wires and header bolts
Old Apr 13, 2009 | 10:14 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
I'm gonna be buying the 2055's off of jegs on thursday and i wanted to make sure that these header bolts are the correct size
http://www.jegs.com/i/Stage+8/868/8911/10002/-1
and are these wires sufficient? for the 2055's?
http://www.jegs.com/i/MSD/121/5570/10002/-1
i don't need those special spark plug wire jackets or anything right?
these plugs are alright?
http://www.jegs.com/i/Accel+Spark+Pl.../276S/10002/-1
thanks guys
1990 RS 305 TBI
Old Apr 14, 2009 | 08:26 PM
PneumaticTire's Avatar
Car: 1986 Camaro Z28
Transmission: Who orders an auto in a Camaro??
Axle/Gears: Economy gears..once again, WHY?!?
Re: 2055's plug wires and header bolts
Hello, I have the same headers and also got the y pipe as a kit about 3 yrs ago. Header bolts should come with the headers, I know they did with mine. The plug wires will work fine, as long as they are 90 degree boots. Do yourself a favor too, route the plug wires to come up from UNDER the headers. If I can I will get you a pic i just did mine. Much cleaner and MUCH easier to keep the wires off the headers. I got the JEGS brand wiers though and they are working AWESOME. Check em out they are even a few bucks cheaper, and look great. Just tell em you want OE style under head wires so you can route em they way they are supposed to be.
Old Apr 14, 2009 | 08:50 PM
89ROC-Z's Avatar
Car: 89 IROC-Z
Engine: 370 LSX, LS3 Top End
Transmission: Built T-56
Axle/Gears: 9" Aluminum Center 3.89's
You could try the hooker bolts, and if they come loose just get the stage 8s (yes those you have linked are correct). Plug wires look fine as long as they're long enough to fit under the headers. Mine are under the headers.
Old Apr 15, 2009 | 12:36 PM
Car: 1990 Camaro RS
Engine: V8 305 TBI
Axle/Gears: 3.08
Alright, thanks alot pneumatic and 89IROC, yeah, the wires have *90 boots, i'm just hoping that they are long enough to route under the headers.
I read alot about the headers and the install already and decided that it's best to get the locking header bolts, i work at a tow yard and a friend of mine there installed headers and he didn't get locking bolts and he had to keep retightening them, and when he would forget to there would be a gap about 1/8 of an inch wide between the header and head sometimes, so i don't want to have to keep tightening them down, best to just lock them down and be finished with it.
Thanks alot again guys.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
Infested
May 22, 2018 11:56 PM
Derick15
Sep 17, 2016 05:28 PM
