Clearance ?
Old Apr 19, 2009 | 10:13 AM
Americanmouse's Avatar
Car: 1988 IROC-Z28
Engine: L98(383tpi) modified
Transmission: 700R4 rebuilt
Axle/Gears: 3:73 10bolt rebuilt
Clearance ?
I have a Hooker long tubes with a Mufflex system. And currently my ground clearance is I can roll a pop can under with out hitting the Mufflex and thats about it. This is with a 150,000 mile plus on the current stock spring & strut ride hieght. I'm replacing the struts and springs with Lakewood Struts And Morrosso Trick Springs. I have the option of using uncut trick springs or 1" cut trick springs.
My question is; due to the old spring strut sagging if I go with the new 1" cut springs would the ride stay the same as the old or would it get better/worse? Or should I use the new uncut springs which will probley raise the front more than I would like for looks.
I also have LCA relocation brackets that I can use too.
Old Apr 20, 2009 | 12:13 PM
Car: 1988 IROC-Z28
Re: Clearance ?
Theres got to be a few people who have had to deal with this problem!
Old Apr 20, 2009 | 09:08 PM
Car: 1988 IROC-Z28
Re: Clearance ?
I'm guessing theres no replys maybe because this is more a suspension question so I'll move it over there!
z 28 jari
Sep 14, 2021 10:03 PM
91 SrS
Oct 7, 2015 04:32 PM
86z89iroc
Oct 5, 2015 01:04 PM
Night rider327
Sep 16, 2015 02:20 AM
