Dynamax or SLP Bullet Muffler?
Old May 8, 2009 | 12:52 AM
The Project's Avatar
Car: 89 IROC
Engine: 305 TPI / ZZ4 cam
Transmission: Stage 2 700R4, LS1 driveshaft
Axle/Gears: Strange 3.42 w/ Auburn
Replacing my old flowmaster...gave up the ghost after 15 years and I need a new 3" muffer for my IROC.
Looking at some deals on a Dynamax bullet and SLP loudmouth (original) bullet style muffler.
Is one better than the other in terms of flow?
I figure the Dynamax would be a bit louder...
Old May 8, 2009 | 11:17 PM
slow305rs's Avatar
Re: Dynamax or SLP Bullet Muffler?
I would take the SLP over the Dynamax.......
I think you would be happier with the flow and sound.
Old May 9, 2009 | 12:30 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
have you thought of a chambered exhaust - you can get them with a 3 inch internal and 3 1/2 external and up to 26 inches internal - 31 inches external. very reasonable and sound great - a little loud but not tinny. put it in as your mid pipe and take out the muffler and run it as duals out the back.
Old May 15, 2009 | 09:51 PM
90tararebird's Avatar
Car: 1990 trans am
Engine: 350 tpi
I had a Dynamax and it rotted in less than four years.
Old May 25, 2009 | 08:31 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
I would go with the SLP. Do i need a welder to do just a muffler on my camaro do you think? Its the stock exhaust, I just wanna flowmaster just to give it a rumble
Old May 25, 2009 | 08:42 PM
Car: 1990 trans am
Engine: 350 tpi
You might want to crawl under and check out the condition of the exaust from the cat back. Yours is 26 years old, mine rotted out in like 8 years. Might save you some suprises when you go to do it.
Old May 25, 2009 | 09:20 PM
Rayzor32's Avatar
Car: '89 IROC-Z
Engine: 355
Transmission: 700r4 edge 3000 stall
Axle/Gears: 9-bolt 3.73
I think the dynamax sounds better than the loudmouth imo
Old May 31, 2009 | 07:08 PM
stage20's Avatar
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
the loudmouth is horrid if you have any kind of power.
it has no tone at all.
its just nasty.
a dynomax bullet, or a magnaflow style bullet is a lil more quiet.
Linson
Oct 24, 2025 02:00 PM
no green
Jan 9, 2016 09:22 PM
