Will this set up be good for my car?
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
I am looking at a set of slp headers. they have 3" collectors, but the ypipe is only 2.5". I would rather have a 3"y but the car will have no cat, & a very unrestricted muffler to help with flow. It will also be turned down before the axle.
So I will have the headers, 2.5y, 3" pipe turned down before the axle, & a muffler. Will this work on my lo3 when i get it up to 3-400hp? Only reason I have to ask is that the pipe would go from big, to small, then back to the bigger pipe. Please help guy's. This deal will not last long. In fact I am buying it asap anyways, but please do send info.
Car: 1987 Iroc Z 1990 RS 1991 RS
Engine: 454 soon 496
Transmission: Soon T56
Axle/Gears: 308 Posi
Re: Will this set up be good for my car?
In opinion it should work. the only thing i would say is if you don't have emissions. Then crap out that cat. My opinion i shouldn't think there would be any if all difference in it. sounds like a good idea what ur doing pics
Car: 89 RS
But what about the 2.5y? That's the stock y right? Think ill hold off for a 3"y. The 3"y will take some time though, cause I have very lil money right now, so pics will be a while. Any advise about a stock car, or truck that has a 3"y? I could go junk yard shopping if I knew what to look for. Maybe a diesel powered truck will have the y im looking for?
Car: 91 RS vert/ 89 iroc vert
Engine: 305 TBI/305 TPI
Transmission: 700r4Xtwo
Axle/Gears: 10 bolt non-pos. B/W 9 bolt pos
the y pipe is not listed on their site anymore, where did you see this?
Car: 94 Silverado
Engine: 383 Vortec TBI
Transmission: 4L60
I think you can use the Y pipe off of a tbi truck. It's a little less restrictive than the f-body but it's not 3". You keep it up and you are going to have to dive into chip burning pretty quick. lol
yea i believe stock is 2.5 for the y. Are you using stock manifolds. the reason i ask it there is a flowtech y pipe that goes either stock or the flowtech headers which are shortys that i think is 3 inch y. but do not quote me on that. summit racing or jc whitney i seen it check there you might find what you want. or yes junk yards would might have something if they have a camaro there check it out b/c sometimes they are modified when the owners had the car you might get lucky.
Car: 89 RS
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
with 3 inch y pipe your going to have many problems going around the oil pan, but I have seen it done once on this board by someone. Other than that a 2.5 inch y pipe is enough for most applications. I am running a 2.5 inch y pipe and making 470 horse at the motor. The stock y pipe is either 2 or 2.25 inchs. But if you look at the bends in them, you can tell there is a restriction right there.
Car: 89 RS
well the dude has a 2.5 y. Only thing is that he has not called today like he said he would, & will not answer me now. Hope he didn't blow me off. So If he does I need to know for sure about the stock y pipe. One said its 2.5. One said its smaller. More votes?
Car: 1988 Camaro
Engine: 383 Stroker
but if you look at the design you would notice it would not flow as good as an aftermarket one
Car: 89 RS
OK guy's I need your input on an exhaust set up that I found, & I need it asap before I miss another deal. I found a set of long headers. 3" collectors, Into a 3" y pipe, into 3" single pipe to the rear axle.
All I would need is the muffler. I can get the set up for about $50. The only thing is no o2 bung, & two of the pipes are crushed for clearance. o2 bung is no problem. I can have one welded in. The worst of the two pipes is about 50% smashed. The second is about 25% smashed. My car is stock, so im thinking it will still kick as s to get this set up.
I wonder that since the headers are smashed, will it cause any trouble in the motor, since the headers wont flow equal, out of all 8 pipes? Its a tbi, so no worry about the car running rich. If I get the headers I will have to do this first thing in the morning so I don't miss out on them. Or should I miss out on them?
Car: 1990
Axle/Gears: stock
striker - i am using hooker 2055 with a 3 inch y pipe and my muffler is a 31 inch chambered exhaust 3 inch internal diameter and 3 1/2 inch external. 85.00 to my front door. i am using it for the mid pipe to run through then over the rear end and out. very few bends and lots of open pipe. i am keeping it just one pipe no pretend duals - no one will see it anyway.
Car: 89 RS
IROCZDAVE (88-L98)
Oct 6, 2016 09:08 AM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
