Converting Headers For Emissions!
Old Jun 4, 2009 | 01:30 PM
DeathMetalTony's Avatar
Car: 2002 GS300 Sport Design
Engine: 3.0L 2JZGE
Transmission: 5-Speed Shiftable Automatic
hey there first of all i have a probloem since i do live in california, my question is am I able to get a set of stock exhaust manifolds and cut of the tubing that goes on top for the smog stuff? cause the set of headers i have there either flowtech or dynomax i cant really remeber to be honest they have a tube thing for the o2 sensor but it needs to be drilled out too. so my idea was would i be able to take the smog tubes that go on top of the exhaust manifolds and drill the holes on the headers and weld them in place together? i need some pretty good ideas on what you people thing or what should i do or so, thanks.
Old Jun 5, 2009 | 12:33 PM
Engine: 3.0L 2JZGE
Re: Converting Headers For Emissions!
does anyone have any ideas or suggestions how this might turn out to be?
Old Jun 5, 2009 | 12:58 PM
Stephen's Avatar
Car: 87 GTA
Entirely possible to physically be done, but still wouldn't pass an inspector with a good eye, since it wasn't made by someone who paid the state to get the EO #.
In other words.....State didn't get their $ for it, so it ain't legal! Why do you think the SAME headers from a manufacturer, one with SMOG tubes cost $400/and the same ones without cost $100.
Old Jun 5, 2009 | 01:15 PM
Engine: 3.0L 2JZGE
So your telling me Stephen that is possible to do this? i mean cause i wont have a probloem getting the car smog or so by friend that has a shop, i never asked him if could smog my car the illegal way but i wouldnt want to either, so yeah, thanks for the help dude at least i know whats my next project for my ride, thanks Stephen.
Old Jun 5, 2009 | 07:22 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
if you had a welder it would be pretty easy aslong as you had the headers out of the car.
Old Jun 5, 2009 | 09:26 PM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
those air tubes will not fit right to your headers. they will have to be going into the top of each header tube. i just found some one who cut their air tubes off and bought them. i did this to my tes headers a few weaks ago
Old Jun 5, 2009 | 09:46 PM
Stephen's Avatar
Car: 87 GTA
The stock A.I.R. tubes are 4 tubes, 1 per exhaust tube.
You could weld the correct nuts to your headers, then thread the stock A.I.R. tubes in, making them appear to have been made that way. And have the ability to just unscrew them, them put in NPT plugs, if you were ever so inclined to do that.
Might be tricky lining up the threads to each section. Not even sure that would be possible. Worst case? Cut & weld.
Old Jun 5, 2009 | 10:10 PM
Engine: 3.0L 2JZGE
yeah there off the car of course, thats the reason i want to get some at the junckyard so i could play around with.
Engine: 3.0L 2JZGE
so did it work for you by any chance?
Old Jun 5, 2009 | 10:11 PM
Engine: 3.0L 2JZGE
yeah your right Stephen about having a way where i could take them off and re-put them back on that would be neat.
Old Jun 5, 2009 | 10:15 PM
91_RED_Z28's Avatar
Car: 1991 Camaro Z28 TPI
Engine: LB9 SBC 5.0L 305ci
Transmission: 4 Speed 700R4
Axle/Gears: Detroit Locker w/ 3.26 Final Gears
i agree with Stephen, and just cut and weld, it will be so much easier and alot lest hassle trying to line up the air tubes with the header tubes...
Old Jun 6, 2009 | 08:30 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i dont think it would be too hard to do. I believe the threads are pipe thread, so you will have to buy threaded parts to weld to the headers.
Just screw the threaded parts to the AIR tubes, locate the tube assembly on the header and weld. Then remove the AIR tubes and drill a hole in the header through the welded nut. Or i suppose you could mark and drill the holes first, but this way its idiot proof.
Old Jun 6, 2009 | 09:04 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
I see you are a California boy so let me tell you straight - you will never pass smog! each set of aftermarket neaders have to have a CARB approval number assigned to it - you personal set of aftermarket make overs dont.
Old Jun 6, 2009 | 11:48 PM
90-irocdx3's Avatar
Car: 1990 iroc z
Engine: LSX 376 F1A
Transmission: 4l60e
Axle/Gears: 12 bolt 3.42
if you want to buy some hooker 2055 headers i have a pair that are used would sell them fairly cheap you just need a y pipe mine was crushed by a mechanic. i have lt's now have any use for them. pm me i am in sb
Old Jun 7, 2009 | 12:05 AM
Stephen's Avatar
Car: 87 GTA
I saved this from a post awhile back.....
"Guys.......just found the correct part number for the manifold plugs. Edelman number 120500. Should be available at most GOOD auto parts stores. I'm picking mine up from Auto Zone tonight. Thanks to Randy from Eckler's! "
Or just go to Home Depot/Lowe's and buy 1/4" (IIRC) NPT pipe plugs.
Old Jun 7, 2009 | 11:28 AM
Engine: 3.0L 2JZGE
im telling **** like that dont matter for me and trust me i have my exhaust dump in front of my rear passenger tire and that dont matter either they still do my exhaust there really good friends but they dont do illegal stuff though.
Old Jun 7, 2009 | 11:33 AM
Engine: 3.0L 2JZGE
i try loking that part number up on the autozone website, and it came up with nothing.
Old Jun 7, 2009 | 11:35 AM
Engine: 3.0L 2JZGE
yeah i was looking at my stock exhaust and my friends edlecbrock headders and i like how the headders they put the air tubes on thop and the stock manifolds they have them on the side so been on top you get more clearence that way, so thats always good whentrying to change plugs either on the left or right of the car.
Old Jun 7, 2009 | 02:17 PM
Engine: 3.0L 2JZGE
does any one have a set of air tubes i could bum off?
Old Jun 10, 2009 | 11:23 PM
Engine: 3.0L 2JZGE
any one out there that could help with some air tubes by any chance?
92projectcamaro
Jan 18, 2016 08:00 AM
69 Six Pack
Oct 5, 2015 07:51 PM
andy74
Sep 3, 2015 08:41 AM
theurge
Aug 21, 2015 12:46 PM
