Headers or No?
Old Jun 8, 2009 | 04:21 PM
ckyfreak2010's Avatar
Headers or No?
Ok so i have a 92 rs v6, im not sure how large the y pipe is itself, but from the cat ( which is gutted) i have a 2 1/2" pipe running to my muffler, which is a glass pack, and after the glass pack is just a little tip.
Now my question is, if i put headers on my car, will there not be enough back pressure? and is not enough back pressure bad?
Old Jun 8, 2009 | 05:15 PM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Headers or No?
If you're not going to replace the Y-pipe at the same time, I wouldn't bother with headers. The factory Y-pipe on my 92 was tiny, about 1.25" on the inside IIRC. It's a double-wall design so you can't just measure the outside to figure out the inside diameter. A 2.5" catback should be just fine if you have a high-flow or hollow cat.
Old Jun 8, 2009 | 05:31 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
Re: Headers or No?
Headers for sure. The less back pressure the better.
Old Jun 29, 2009 | 03:31 PM
MY87LT's Avatar
Car: 1987 Camaro LT
Engine: LG4 w/ SLP headers & a 3" catback
Transmission: THM700R4 (Stock)
Axle/Gears: Stock 2.73 gears. No Posi
Re: Headers or No?
Did you eventually get the headers?
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
91 SrS
Oct 7, 2015 04:32 PM
Bigold4x4
Sep 28, 2015 05:21 PM
