do full length headers= equal length headers?
Old Jun 26, 2009 | 12:19 PM
91 camaro rs's Avatar
Car: 91 rs
Engine: 305tbi
Axle/Gears: 3.27 9bolt
are the two the same thing? are their any fitment issues involved in installing either? i.e. ground clearance, removal of part of compressor bracket?
Old Jun 26, 2009 | 12:40 PM
Reid Fleming's Avatar
Car: 1989 GTA
Engine: SuperRam 350
Transmission: Pro Built S/S TH700R4
Re: do full length headers= equal length headers?
Full length = long tubes....The primary tubes run farther before they get to the collector. For an extreme example, here's a C5 Z06 with long tubes.
Equal length = each primary tube is the same length. Can be any length of header as long as they're the same length.
Old Jun 26, 2009 | 12:42 PM
mmadden55's Avatar
Car: 86 Firebird
Engine: 305 SBC
Transmission: 700 R4 TCI
^True. Go with the long tube more Torque.
Old Jun 26, 2009 | 01:12 PM
gcgarner's Avatar
Car: '92 T/A WS6 Vert/1956 Chevy Nomad
Transmission: 700r4 w/ Transgo Kit
Axle/Gears: 3.42 LSD
You guys aren't answering the question.
No, they are not the same thing. Long tube (full length) headers are like the ones the guys mentioned above. Equal length headers can be shorty headers. It means that ALL of the tubes for EACH cylinder are the exact same length. This set is for a six-banger ... but you get the idea.
Notice how all the tubes are the same length and just bent to fit to the cylinder?
They say that equal-length headers will allow about 2-3 more horsepower than non-equal-length headers on a 305. But I hear it's a bear to get to the spark plugs.
Old Jun 26, 2009 | 01:42 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Full length just talks about length, equal-length is, as has been mentioned, something that means each cylinder's primary is the same length. This is a big deal for race cars, but you wont see any for our cars, at least none that I'm aware of. The sbc firing order makes them a bit useless anyway actually. You'd have to get a goofy set that wrapped over one cylinder from each bank to the other side to see any real performance increase. These racing V8's are generally single-plane so all the pistons fire much more evenly.
Here's a set for a F1 V8.
Old Jun 26, 2009 | 01:52 PM
TA's Avatar
TA
Car: '88 GTA, 90 Formula
Engine: 5.7 TPI, fed growth hormones
Transmission: 700r4 4u2?
Axle/Gears: 9bolt
In our case, because of the limited space to work in, Equal length headers are very uncommon and can usually only be accomplished by running small primary tubing, which looses you far more power than the equal lengths would win back.
TA
Old Jun 27, 2009 | 01:19 AM
Car: 91 rs
Engine: 305tbi
thanks for your time and knowledge.
eric
Hotrodboba400
Dec 10, 2019 07:07 PM
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
92projectcamaro
Jan 18, 2016 08:00 AM
SG91camaro
Sep 5, 2015 10:27 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
