The debated question.
Old Jul 8, 2009 | 03:05 PM
NEWDUCK's Avatar
Car: 1982 indy 500 pace car
Engine: 400 small block of doom
Transmission: The stock 4 speed
Axle/Gears: Stock axle and gears
Oh yeah first post time. Glad I found this site. So what I have is a 400 small block that is fairly built. Now if my motor was stock I would just go with a 3 in single pipe down my car. My question is should I just buckle up and pay the price for a dual set up? Or is the power diffrence from the single to dual barely noticable. But one would think dual means more flow which means more power. The main reason im asking is because my uncle dyno'd a 3 in single vs a dual(not sure on the size) and he said the single provided the same results but that could of been on just a stock set up. I didnt ask on the engine size ect.. but i figured the pros on this site have been there done that. Im running headmen long tubes if that makes the decision any diffrent.
Old Jul 8, 2009 | 03:28 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
Re: The debated question.
im no expert but most people say go with a single pipe. same power gains, different sound. you get more ground clearance with a single pipe if thats a concern
Old Jul 8, 2009 | 04:52 PM
92RS(real slow)'s Avatar
Car: 92 RS(sold) 1989 IROC-Z
Axle/Gears: ones that turn
I say single daul exhuast is overated
Old Jul 8, 2009 | 04:54 PM
igotta355z28's Avatar
Car: 1991 Z28 1LE
Engine: 370CID GenIII
Transmission: 4l60e
Axle/Gears: 4.33 Moser 9inch
my buddy puts down 620hp to the ground in his camaro through a 3inch single exhaust. Most people go overboard on ther exhaust, single will do just fine...
Old Jul 9, 2009 | 09:24 PM
NEWDUCK's Avatar
What does he run to put that much down to the ground? Ground clearance is def an issue and if you guys are saying single is just as much power might as well go with that cause its way cheaper.
Old Jul 9, 2009 | 10:54 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
what about the tail - do you like just one exhaust there or do you think branching off into dual exhaust on the back side of the rear end is the best.
for now i have everything for a single up and over the rear end and i just cant see a reason for spliting it and causing back pressure at the location of the split. it seems a bit of waste.
and if you go for the single pipe what do you use for the tail section - is it invisible - like the stock fake 90 duals, or do you just run the pipe out the back?
i forgot to add that the muffler is actually a 3 inch internal - 31 inch long chambered exhaust and im using that as the mid pipe so there is no muffler mounted that can be seen.
Old Jul 10, 2009 | 04:26 PM
Car: 1991 Z28 1LE
Transmission: 4l60e
he runs a370 CID Gen III motor (.030 6.0L truck motor) with a D1SC super charger, and i was wrong he put down 683hp with the belt slipping....
on the tail end just go with whatever u like, i like to have 2 tips...
ZZ3Astro
Aug 13, 2019 12:57 AM
fbodyfreakls1
Oct 6, 2015 06:34 PM
corey8084
Sep 17, 2015 02:56 PM
Wylecoyote08
Sep 8, 2015 08:26 AM
Ian Irvine
Sep 4, 2015 08:08 AM
