modifying hedman 17478 y-pipe
Old Jul 16, 2009 | 04:53 PM
Brennan's Avatar
Car: 1984 Z28 HT,2006 2500HD
Engine: 5.7L, 6.6Llbz dmax
Transmission: 700R4, 6 speed allison
Axle/Gears: worn out 3.73 posi
im thinking about buying the hedman 68470 headers and 17478 y-pipe for my 350. the thing is i need a 3 inch outlet on the y-pipe. ive read about people modifying the y to have a 3 inch outlet, which brings me to my question what exactly is needed for the mod? where do i cut and what do i weld back on? thanks in advance
Old Jul 17, 2009 | 05:12 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
Re: modifying hedman 17478 y-pipe
About to modify mine that way, I'll let you know...
Old Jul 18, 2009 | 02:25 PM
Brennan's Avatar
any chance you can take before/during/after pics?
Old Jul 18, 2009 | 04:32 PM
J91's Avatar
J91
Yes, I picked up a 3" pipe ( off of a truck) from Midas and had them, swage one end to fit over the collector, the other end was already swaged to slip over 3". I will get the Midas part #. It cost me $57.00, ouch!
The plan is to cut off the ball flange on the after cat pipe, cut off the small pipe (test tube) that is on the collector and slip it on and weld them up? I'll get pix and send 'em to you. plan on doing it this week. PM me your email address...
Old Sep 29, 2009 | 06:37 PM
mos68x's Avatar
Car: 1991 Camaro RS/Z28
Engine: 357 Edelbrock Intake & Holley Carb
Transmission: WC T-5
Axle/Gears: whatever stock is
you got any pics? this isn't exactly what I had in mind, but it's interesting. I was thinking of cutting off the y pipe part and using the rest of it for true duals. easier than trying to make the flanges fit right with the bends right on them, just not sure if it would be cost effective.
Old Sep 30, 2009 | 09:40 AM
donnis618's Avatar
Car: 1984 camaro Z28
Engine: 355
Don't they have adapter pipes at autozone, advance, etc? I think they carry some that will fit a 3" pipe. check it out.
Old Sep 24, 2013 | 11:07 AM
rwstegne's Avatar
Car: 1989 Iroc Z 5.7L
Engine: 5.7L
Axle/Gears: built 4.10s
Any pictures ?
Old Sep 28, 2013 | 01:43 PM
Atilla the Fun's Avatar
On Probation
Engine: several
Transmission: none
Axle/Gears: none
The entire Y-pipe needs replaced. Considering it's a 350, and considering the header primary tubes are 1.625", the 2" pipe under the oil pan is far too small. Dual 2" into a single 2.5" is enough for a stock 245 HP L98, but those headers need 2.5" to a proper 3" junction, not just adapting a 2.5" pipe to a 3" cat.
Truly sucks that a big-name company can't offer a tolerable y-pipe. Really, you can forgive Flowtech for dumping the side's 2.5" into the left side's 2.5" because that's cheap Chinese junk. And their headers are only 1.5" primaries. Again, adequate for 245 HP, but way wrong.
hectre13
Car Audio
26
Mar 3, 2022 05:38 PM
InfernalVortex
Apr 20, 2021 11:31 AM
meeklay812
Oct 1, 2015 03:46 PM
Zell1luk
Sep 29, 2015 10:36 AM
