02 sensor removal questions
Old Jul 29, 2009 | 01:45 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
Transmission: '96 T56, Hurst Shifter, Mech VSS
Axle/Gears: 3.45 9 Bolt
Whats easier, removing it from the top or the the bottom? (I looked at the top and it looks like the air tubes, master cyl. will be in the way.)
Should I use some PB blaster first to help it remove easier?
Should I put anti-seize on the threads of the new sensor?
Old Jul 29, 2009 | 02:33 PM
kkingsrulee's Avatar
Car: 1990 Camaro RS
Engine: V8 305 TBI
Transmission: W/C T5
Axle/Gears: 3.08
Re: 02 sensor removal questions
I removed my o2 sensor in my room at home, I removed the manifold, but you can probably do it from above. I believe it's a 17 or 18 millimeter open end wrench.
Old Jul 29, 2009 | 02:37 PM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
I got the universal o2 sensor socket, but with all the clutter above the manifold i have about 1/2 inches for the rachet to move.
Thats why im wondering if i should take the air tubes off the manifold in order to have more room.
Old Jul 31, 2009 | 11:05 PM
Pocket's Avatar
Car: 91 Trans Am
Good luck getting the tubes off intact
O2 sensors are not that difficult to remove/replace. Invest in a set of extensions and a universal joint
Old Aug 1, 2009 | 01:17 AM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
O2 socket, 12" 3/8 extension and 3/8 ratchet, no issues (might need a cheater bar on the ratchet though if it's the original O2)...
Old Aug 1, 2009 | 03:37 AM
J91's Avatar
J91
Car: 91 Z28,64ImpalaSS4094spd,67 Galaxy
Engine: Dart 415Profiler hd,cmprlrs,Hlly750
Transmission: Built 700R4, 3200 stall
Axle/Gears: 3:89 Moser 9"
PB Blaster -Yes
Anti-sieze - Yes
Airtubes - Work around them...
Old Aug 1, 2009 | 08:25 AM
camaro1185's Avatar
Car: 1988 Iroc
Engine: 5.7L
thanks. got it o2 off and the new one in. I was easy.
although now the car runs even more rich.
why can nothing be an easy fix on these cars.
Old Aug 1, 2009 | 06:25 PM
Pocket's Avatar
Car: 91 Trans Am
Because fixing the real problem takes effort
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
redmaroz
Aug 16, 2015 11:40 PM
gta power
Aug 13, 2015 06:15 AM
3rdgenparts
Aug 8, 2015 07:09 PM
