Ceramic Spray paint
Old Jul 29, 2009 | 02:03 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
Transmission: 700R4 w/2800 stall
Ceramic Spray paint
I bought some VHT ceramic spray paint, and there is a curing process that requires baking.
It doesn't say NOT to bake it in a regular kitchen oven, but I believe i have read comments saying not to use the kitchen oven.
Any feed back from people who have used the ceramic coatings before?
I would use the cure process on the car using the heat from the engine, but the motor is new and will not be usable for a while, plus I'm sure running the motor as reccommended for curing will not be possible as soon as it is runnable.
I'd like to use the kitchen oven so I don't have to out source the cure process, but I don't want my food to taste/smell nasty, or for my wife to kill me.
Old Jul 29, 2009 | 02:38 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Re: Ceramic Spray paint
Do you have to cure them that way because i did no do that to mine i just painted them and put it on the car
Old Jul 29, 2009 | 03:19 PM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
The can recommended curing, and said the anti-corrosion features would not be effective w/o curing.
Old Jul 29, 2009 | 03:22 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
So i am gonna have to take them off and paint them again do you know any places were they cure them or whats the the temp it needs
Old Jul 29, 2009 | 03:25 PM
UNCLE TOM's Avatar
Car: 91 R/S , 89 dodge p/u
Engine: L31 GM crate re-cammed , 318
Transmission: T-5 , 4 speed auto
Axle/Gears: 3.42 , ?
do not use your household oven . who knows what toxic chemicals you might release . then if food is cooked in it , who knows ? had a friend who tried it years ago with a plastic steering wheel . tried it at 350 for 15 mins. poor SOB was up till 3AM installing new stove . ( don't mess with mom's stuff ) try and pick one up at a yard sale . many people have done this with very good results . good luck .
Old Jul 29, 2009 | 03:33 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
I am gonna look for a stove in the yard sales to check if i find one thank you for the info. i did not know that
Old Jul 30, 2009 | 06:57 AM
zride91's Avatar
Car: 1991 Z28
Engine: 383 TPI
JR350tpi, all the instructions w/ temps, times, and cycles are on the can. Please note, that you can probably skip the whole oven process and cure the paint on the car. Go to a parts store, take a look at a can to see what is involved.
UNCLE TOM, thanks for the verification! My father-in-law bakes his car parts in his kitchen oven, but he doesn't always do things the common way...
Old Jul 30, 2009 | 09:10 AM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
if you have a gas bar b que you can take all the guts out - put a sheet in to prevent fire from hitting the paint and turn it up to high.
mine goes to about 600 degrees and natural gas is clean, and you are outside so no problem with fumes.
Old Aug 20, 2009 | 08:43 PM
NatesZ/28's Avatar
Car: '00 Regal GS/'87 T.A WS-6
Engine: stock 3800 series II/stock 5L TPI
Transmission: fwd auto/stock 700r4
Axle/Gears: wrong wheel drive/3.23:1 Posi
buy a cheap-*** toaster oven from the thrift store. Problem solved for any small stuff
Old Aug 21, 2009 | 04:12 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I used our oven to cure the vht paint on my headers. Never had any problems after curing them in it.
Old Aug 21, 2009 | 04:41 PM
400Z28Racer's Avatar
Car: 85 IROC-Z
Engine: magflatoVE
Axle/Gears: 9" 411
I got a similar kit from Eastwood, and I cured the headers on the car. However, the results were NOT impressing, and I was not able to get 'em shine.
Old Aug 21, 2009 | 05:49 PM
aciddrop2804's Avatar
Car: 1984 camaro Z28
Engine: 5.0L H.O. L69
my friends buddy actually modified a kitchen oven for this purpose. he now charges people to powder coat and bake things for them like wheels, exhaust, just about anything really. he can make some pretty good looking stuff.
Old Aug 21, 2009 | 10:49 PM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
How much would your friend charge me
Old Aug 21, 2009 | 11:53 PM
gurkgurkgurk's Avatar
Car: 86 Camaro iroc-z28
Axle/Gears: 3.42 Posi
well the problem is that the paint your using is bad for you, it probably causes cancer and yaddayadda. anyways you can try to do it in your oven but id say it wouldnt be very good for your health or anything else that gets cooked in the oven afterwards. i suggest u pick up a cheap gas oven at a yardsale or sears. i used to work at sears an i know they sell one for about 200 bucks and it has a decent amount of space inside. and you can just hook it up to the gas in your garage or basement, where ever your furnace is and you can just use it for all your powdercoating and painting needs.
Old Aug 22, 2009 | 12:36 AM
I'm pretty sure he only does local stuff. We have this big cincinnati forum called stangbangerz(you guessed it, a mustang forum ) and he pretty much only operates on there. my freinds a big foxbody guy(so are half the people in cincinnati apparently). it kinda sucks becuase most of the local custom shops are geard toward fords.
Old Aug 23, 2009 | 07:43 AM
chads89ta's Avatar
Car: red 89 t-top ta
Engine: 305 tpi
Transmission: t-5
Axle/Gears: 9 bolt soon
i used my portable gas heater which is propane.made a backstop and put some sides up, then set my headers in front on the concrete. and turned them a few times.
Old Aug 24, 2009 | 12:34 AM
SiCkRs's Avatar
Car: 91Z28
Engine: 5.7 ls1
Transmission: 4l60e
Thank you
Old Aug 24, 2009 | 01:24 AM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
Just for my two cents on this....I used the VHT coating on the WHOLE exhaust system....headers all the way to the tail pipe tip.....I put it on the car and ran it like it says on the can.....like run 10 min...cool 10 min....run 10 min...etc. etc......I have had it on there for some time now....and not a single problem ever with it....still looks like the day I put it on there....
Old Aug 24, 2009 | 04:17 PM
l_dis_travlr's Avatar
Car: 90 Formula -- tot resto in progress
Transmission: 700R4 w/ 2500 stall, by Owen @ ARD
Axle/Gears: 3.23 posi disc
I've cured lots of VHT items in my oven.
There is a definite aroma released during the process, so venting
the HOUSE may be an issue. (Possible solutions -- set it when you're
going out for awhile. If oven is equipped w/ a timer, even better.)
Oven interiors are VERY non-porous non-absorptive porcelain.
Afterwards, I leave the oven open until the odor is gone. Again,
ventillation can be an issue, but not insurmountable.
And I haven't yet experienced any negative effects on cooking --
at least for the pizza & cookies that I do in the oven.
tony_c's idea of the grill is a brilliant alternative.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
TheExaminer
Sep 28, 2015 02:28 PM
cstrobel65
Sep 16, 2015 11:54 AM
neilb
Sep 15, 2015 05:06 PM
TheExaminer
Sep 6, 2015 11:40 PM
