What's the fastest shorty header/single exhaust car?
Old Dec 26, 2009 | 09:02 PM
LilJayV10's Avatar
Car: 89' T/A, 00' Firehawk
Engine: 406 Roller
Transmission: TH700R4 w/2800 stall
Axle/Gears: 3.23 Posi
I am trying to find out what the fastest someone has been with shorty headers and single exhaust.
I have dyno don headers, 2 1/2 y pipe into 3.5 pipe into 4inch mufflex.
I am trying to decide if it would be worth it go to hooker L/T's w/ 3inch y pipe.
Old Dec 27, 2009 | 07:56 AM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Re: What's the fastest shorty header/single exhaust car?
i ran a 11.72 with dyno dons headers into a 3 inch exhaust with a 3 inch cutout. I know I can get down into the 11.50's with this setup. How fast are you wanting to go?
Old Dec 27, 2009 | 11:18 PM
ziggy89's Avatar
Car: 91 Firebird Formula
Engine: 383
Transmission: built 700r4
Axle/Gears: 4.11, 9inch
low 13s all day on heddman shorties and a flowmaster cat back. thats on a pretty mild 383
Old Dec 27, 2009 | 11:20 PM
91interceptorZ's Avatar
Car: 91 B4C "police special service"
Engine: L98 494hp
Transmission: tko-600 on order
Axle/Gears: 3.23 true trac
low 12's on mine, at somewhere near 4,000 feet altitude (idaho). flowtech shorty headers, into two 2 1/2 into a single 3 1/2 through a hooker aerochamber.
Old Dec 28, 2009 | 10:58 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Jerrywho went 11.61 @ 115 with 200 shot
Also...you need to read this thread:
https://www.thirdgen.org/forums/tpi/...lts-added.html
Old Dec 28, 2009 | 01:59 PM
LilJayV10's Avatar
Engine: 406 Roller
I am building a solid roller 406 w/ AFR heads. Power should be around 560-570 according to AFR.
I hope to run mid low 11's.
Old Dec 28, 2009 | 03:07 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
"I am building a solid roller 406 w/ AFR heads. Power should be around 560-570 according to AFR.
I hope to run mid low 11's."
I don't see anything holding you back. Dyno Don's short tube headers will not hold you back. In fact with that much power you will be getting very close to the 10's if not a 10.99.
Old Dec 28, 2009 | 10:19 PM
LilJayV10's Avatar
Engine: 406 Roller
I hope to get to that. I wonder how many passes the 7.5 rear will take.
I am planning on taking off the flowmaster and put a magnaflow muff instead. The magnaflow is suppose to flow way better.
Old Dec 28, 2009 | 10:34 PM
Engine: L98 494hp
hooker maxflow's are the best flowing, the second is the aerochamber.....I'll try to find the muffler flow bench testing sheet and post it back on here.
Old Dec 28, 2009 | 10:40 PM
Engine: L98 494hp
Here is the flow test numbers.....
Old Dec 28, 2009 | 11:44 PM
Car: 1989 GTA
Engine: 369 TPI
I think you will have that 10 bolt crying uncle in short order. The saving grace is you are running an automatic trans. I think any of the straight through muffler designs such as DynoMax and Magnaflow will get the job done. The bigger the diameter the more CFM.
Old Dec 31, 2009 | 03:08 PM
6speedIROC's Avatar
Car: 86 IROC
Engine: LQ4 6.0L
Axle/Gears: 3.55 8.8
I run MAC 1-5/8" shorties/3" flowmaster pipe with a single 3" in/out Magnaflow welded. Car ran 12.6@114MPH. It's getting longtubes and larger exhasut soon though.
Old Jan 1, 2010 | 10:20 AM
Hawk92z-TDZ's Avatar
Car: 92Z28, 99SS, 83Z28 & 86GTA
Engine: 421, LS1, 327Turbo & 383
Transmission: T-56, 4L60E, T5 & 4L60
Axle/Gears: 4:10, 3:42, 2:73 & 3:27
12.49 @114mph N/A on normal street tires with old school SLP 1 3/4" shorty's, dual magnaflow cat's and an IMCO 3" cat back
Old Jan 7, 2010 | 12:13 PM
LilJayV10's Avatar
Engine: 406 Roller
There is a thread on the LS1tech board that people have picked up 30RWHP going from the 4inch flowmaster dual outlet to a straight 4in muffler like the magnaflow. That's a bunch.
Old Jan 7, 2010 | 09:33 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
A little of topic but since the subject of 10 Bolt strength was mentioned you might consider one of the LPW Ultimate covers. Adds allot of strength with the bearing cap studs and heavy cover. Here's a link to their site. http://www.lpwracing.com/p_capcovers.asp and here's one for their axle tube brace kits http://www.lpwracing.com/p_axletubebrace.asp
Old Jan 7, 2010 | 11:01 PM
LilJayV10's Avatar
Engine: 406 Roller
I have the rear end girdle. I think it's from T/A. The car has went 7.8's on radial tires with a 1.8 60' and is still together.
Old Jan 7, 2010 | 11:17 PM
fast82z's Avatar
Car: 82 Z28
Engine: TT LS
Transmission: 4L80E
Axle/Gears: S60 3.54's
Does it count if there's a turbo in the mix too? I was using what's in my sig., 1 5/8" shortie headers. I had a 5" cutout after the turbo, but a single 3" pipe with the cutout capped. It still dynoed over 520rwhp with 8psi and the 3" pipe and ran at least a low 10.
1992 Trans Am
May 10, 2023 07:19 PM
transaero
Aug 31, 2015 01:14 AM
TheExaminer
Aug 26, 2015 04:59 PM
mustangman65_79
Aug 7, 2015 09:55 PM
