Tucking up muffler and tail pipe?
Car: 1984 Trans Am 15th anniversary
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Anybody got pics of single muffler with the tailpipe tucked up? I was thinking of dumping the duals and going with a single. But I don't want the exhaust to be seen.
Car: 88 Camaro SC
Engine: SFI'd 350
Transmission: TKO 500
Axle/Gears: 9-bolt w/ 3.23's
Re: Tucking up muffler and tail pipe?
Flowmaster makes a system that has a single exit. http://www.summitracing.com/parts/FLO-17151/ I have it, along with a hooker max flow muffler. There's not much to see with the muffler behind the trunk well and the exit off to the side. The outlet sits up in behind the rear bumper skirt, so it can be almost completely hidden if you play with it a little.
This is the closest thing I have to showing what it looks (and sounds) like: http://www.youtube.com/user/dimented.../4/t6cXmHkANEM
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
a truly horrible pic, but its the only on i have from the rear of my current exhaust
cant see the turn down from the rear, and the rest is painted black so it hides well.
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Flowmaster American Thunder 80 series .I had to get on my knees to take this photo.I also cut back the tips about 3 in. so they tucked in better. Now all I need is some rolled tips.I think painting the muffler black would hide mine also.
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
Perfect I want no exhaust to be seen , only heard. Not to mention the single most likely flows much better rather then the "bunch-up-exhaust-smoke" until it comes out the two tail pipe design.
I ordered a Hooker aero chamber to replace my dual setup.
Car: 92 T/A 'vert
Engine: Mild .040 over L98 4 bolt mains
Transmission: Mostly stock 700R4, 2600 Vigilante
Axle/Gears: LS1 3.42
Car: 88 iroc-z/28
Engine: 408 lsx
Transmission: 5800 stall
Axle/Gears: 4.71
4" mufflex with magnaflow muffler. the tailpipe assembly is not part of the kit. it was built out of a 4" elbow.
ban barely get your fingner in between the pipe and the frame.
you cant see it from the back.
I am trying to plan my exhaust on my 85 Camaro , but have a couple of questions....
1) From my headers , I would need to connect the two pipes to a Y-pipe collector and run that to the end, where there would be another y-pipe to split it back to dual exhaust, correct ?
2) I am going to use the Heddman headers from Summit that are short tube, and they have a 3" collector on them, is there any way to keep it 3" all the way back ?
Engine: L69
Transmission: 700r
Axle/Gears: 3:73
That's perfect and exactly what im shooting for. Hooker aero chamber being black helps to.
Car: 1988 IROC-Z
Engine: 427 SBC
Transmission: ProBuilt 700R4
Idle: http://www.youtube.com/watch?v=ZjzPtVme_T0
Light rev: http://www.youtube.com/watch?v=v3ddiCgHXz0
Normal driving: http://www.youtube.com/watch?v=QLvqbVNs87Y
Car: 92 T/A 'vert
Well, I've got mine installed and while it doesn't sound quite as good as yours, (I REALLY need to do the heads/headers/cam/intake now!), it sounds much better than it did.
LT1Formula
Oct 8, 2015 08:34 PM
