glasspacks?
Old Mar 3, 2010 | 06:32 PM
iroczcamarokid's Avatar
Car: 1986 iroc-z camaro
Engine: 305tpi
Axle/Gears: 3:42
glasspacks?
i got a 86 305 iroc how do you put a thrush glass pack exhaust on it?
Old Mar 3, 2010 | 06:48 PM
Drew's Avatar
Re: glasspacks?
You don't. It's an Iroc, not a farm truck.
Old Mar 3, 2010 | 06:57 PM
GeeJenn91RSV8's Avatar
Car: 1991 Camaro RS
Transmission: 700 R4
Re: glasspacks?
LOL...Yeah what DREW said. Don't make a bad name for the rest of us.
Old Mar 3, 2010 | 07:01 PM
skirkland1980's Avatar
Car: 82 S10, 83 280ZX, 84 Z28
Engine: 355 smallblocks..na, 2.8 turbo
Transmission: 85:th350, 84:700R4
Axle/Gears: 85:ford9 4.85, 84:stock 3.24
Re: glasspacks?
i like the moroso spiral flow muffler. it has better sound, wont burn out, and is not much more $ than a glasspack.
Old Mar 4, 2010 | 08:16 AM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: glasspacks?
I have two of the Spiral Flows on my car now and I am taking them off. I know it has the small tube in the middle that is straight through, but the spiral area doesnt seem like it would flow too well. I'm redoing my whole exhaust from the headers back. I'm ditching the dual with no cross-over for an X-pipe system with Magnaflow straight threw resonators.
Old Mar 4, 2010 | 11:24 AM
Re: glasspacks?
what size are your spiral flows? if you're getting rid of them i may be interested buying them.
Old Mar 13, 2010 | 12:46 PM
Engine: 305tpi
Axle/Gears: 3:42
Re: glasspacks?
ya figured it out the hard way any sugegstions for under $200?
Old Mar 13, 2010 | 01:08 PM
92Firebug's Avatar
Car: 1992 Pontiac Firebird Base
Engine: 305 TBI
Transmission: 700r4, B&M shifter & shift kit inst
Axle/Gears: 3:23....10 bolt
Re: glasspacks?
i had glasspacks on my 92 base bird, but i took em off so im running straight cats on a single pipe exhaust. sounds like a farm truck once and a while when the idle gets throaty, but otherwise it sounds more muscly and no i am NOT giving the rest of u a bad name. haha
Old Mar 13, 2010 | 01:19 PM
$750 L98's Avatar
Car: 1989 Formula 350 LSX
Engine: 5.3, 234/228 cam
Transmission: Stage II 4L60e, Vigilante 3200
Re: glasspacks?
If you want cheap/loud/good it will require a bit of work on your end. Take a set of cheap Cherry bomb glasspacks, usually 40-50 for the pair. The take a dremel, cut out the colar holding the perforated tube in, then remove the packing.
Cheap SLP loudmouth.
Just for the love of god don't do glasspacks as they are, Ask me how i know...ok, I want to share anyway lol: http://www.youtube.com/watch?v=ZQhVRIyZtHM
Then compare to Thrush welded 2 chamber mufflers for 30 dollars a piece on the same exact motor: http://www.youtube.com/watch?v=hyRWfFqCQaE
Both are on a cammed LQ9 truck motor with true duals.
Old Mar 13, 2010 | 02:51 PM
Car: 1991 Camaro RS
Re: glasspacks?
The thrush mufflers sound way better than the glasspacks....
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Chris87TA350
Dec 3, 2001 04:53 PM
89Firebird Formula350
Nov 30, 2001 04:56 PM
Chevy Muscle
Oct 8, 2001 08:41 AM
RSS
Sep 30, 2000 12:30 PM
