Headers Shortys or Fullsize
Old Mar 10, 2010 | 01:41 AM
Aztec12's Avatar
Car: 1989 Camaro RS
Engine: 5.0
Ok so im starting my build up on my exaust and am planning to buy some headers now I curious to know whether or not brand matters and if it differs between full size and shorty headers....... Thanks for any help guys i appreciate anything go have to say......
Old Mar 10, 2010 | 02:09 AM
ownor's Avatar
Car: 84 TA / 89 Formula
Engine: LS1 / L03
Transmission: T56 / 700R4
Axle/Gears: 3.73 / 3.27
Re: Headers Shortys or Fullsize
well i'd say it also depends on your engine/power goals and if you're adding any chassis stiffening (SFCs) or drivetrain parts later down the road that could get in the way with those long tubes.
and of course also depends on what kind of money you're looking to throw at it. personally, i think the hooker 2055 are a very decent set of shorty headers with an awesome 3" outlet y-pipe. after all, these do have a CARB EO so there gotta be something to keep noise/emissions down with these -> if you don't need the AIR pipes just cut them and weld them shut. i will also recommend cutting the ball flange down about 1/2 - 3/4" to further enhance flow.
Old Mar 10, 2010 | 06:45 AM
DeathStarr89's Avatar
Car: Still a 3rd Gen
Engine: 450HP 355
Transmission: TH350
Axle/Gears: 9" with 4.11's
Shorties should be plenty for most builds as long as the primaries are big enough to support your power goals.
I got a set of Headman 68460's with the Camaro i just bought, even though they are long tubes they aren't equal length so IMO it's not worth all the hassle for those. I'm not sure about the other LT's though.
Old Mar 10, 2010 | 10:49 PM
antsZRS's Avatar
Car: 1990 Camaro ZRS
Engine: 350 SBC
i think you can personally get a bit more torque and power out of LT's but the ground clearance is whats gonna kill you. i have headman LTs on mine. with UMI SFCs and have no problems. But the Ground Clearance is what sux. but its only a weekend car.
just giving
Old Mar 10, 2010 | 10:51 PM
DemonYusuke's Avatar
Car: 1991 z28 L98 Spec
Engine: 5.7 350 TPI 245\345
Transmission: 700 R4
Honestly it depends on your exhaust goals and if you plan on running sfc's or not. If your wanting to maintain a semi stock exhaust setup shorty's will work wonders as most come with y pipe adapters to fit right in place of our old manifold and y pipe. If your looking at doing a custom exhaust as in true duals, I would recommend long pipes less bends in the pipes and easier starting points. Now if your gonna run sfc's then i recommend putting those in place first, then running your exhaust, if you do it the other way around you'll run into clearance issues later
Old Mar 10, 2010 | 11:30 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Everyone says that you give up ground clearance with longtubes, but I dont think so. I have longtubes on my Camaro and I actually have more ground clearance than my brother who has shorties. I think its more in how you route your exhaust. I have never scraped my headers or exhaust on anything and my turndowns were only a few inches off the ground. I'm redoing my exhaust now and will have a lot of ground clearance when I'm done. And thats with true dual 2.5 inch with an X pipe.
Old Mar 11, 2010 | 06:43 AM
Engine: 450HP 355
Transmission: TH350
Agreed. Mine had plenty of clearance with the LT's.. and it was a V8 on V6 springs to boot.
Old Mar 11, 2010 | 07:07 AM
86TA4SALE's Avatar
Car: 1986 Trans Am
Engine: LG4 305 carb
Transmission: auto 700R4
Axle/Gears: 2.73 open
built91Z28:
I'm sure your front coil-over conversion and k member helped. Unless you did them after the long tubes...
~Matt
Old Mar 11, 2010 | 10:42 AM
Aztec12's Avatar
Car: 1989 Camaro RS
Engine: 5.0
Hey man thanks for all the help i really appreciate it..... But how will performance differ from shorties to Long Tubes?
Old Mar 11, 2010 | 12:08 PM
built91Z28's Avatar
Originally Posted by 86TA4SALE
built91Z28:
~Matt
The coilover was done during the build of the car along with the longtubes. The K-member was after though. I do have my springs at roughly factory hight right now but they still tuck up against the body and dont really hang down. I dont see how the K-member would help though.
NZKnight
Oct 15, 2015 02:47 PM
redformula88
Oct 14, 2015 06:08 PM
Bradsaundry
Oct 7, 2015 04:35 PM
Bigold4x4
Sep 28, 2015 05:21 PM
Night rider327
Sep 16, 2015 02:20 AM
