were to find cheap exhuast
#51
Car: 87 iroc-z camaro
Engine: 305TPI
Axle/Gears: G92 3.23 posi
Re: were to find cheap exhuast
cant you rent them from a place like shucks? or how much is one?
#52
Engine: 305TPI
Yeah as long as you have a saw with a strong blade, the job should be easy. Hangers can range from 5 bucks to 65 bucks (the nice ones). Taking off the old exhaust is the easy part. After you take it off, see if you can sand down the undercarriage a little and apply some undercoat so it wont rust. It'll take some time, but it will be worth it. Just make sure you take your time doing the job, cause if you rush, bad things will happen.
#53
Car: 1988 Pontiac GTA
Engine: L98 5.7L
You could probably get one from a Home Depot rental store. Not sure if you have one of them around you, but I am sure you would be able to find a place that rents them out. Sure undercoat will be a pain in the ***, especially on stands. But, in the long run, it'll be worth it. From the sanding, if needed, the priming, and then the actual undercoat. It'll be a bitch for sure, but look at in the long run. After you do your exhaust and undercoat, you really wouldnt have to worry about underneath the car for quite a while.
#54
Car: 1984 Camaro Berlinetta
Engine: 355
Axle/Gears: Australian 9 bolt 3.27 posi
well I'd love to buy from bandit exhaust, but they do not ship free to Canada. If I were to have it shipped here between shipping and duty, the price will be quite close. I made an offer of 320.00 and they replied saying their price is 320.18
if I were in the states this would be my place to shop.
#55
Engine: L98 5.7L
Yeah, I just bought my cat from Bandit. Great place. One thing you could do for the shipping would be to ship it to a city that is close to the Canada border, then have them ship it out of their to your house in Canada. I'm not sure how its done, but I remember reading about someone that did it for their shipping method.
#56
Car: '91 LS6/T56/9"
Engine: LS6
Axle/Gears: Currie 9"/4.11, detroit truetrac
Check out what I found! They'll be here today so I'll be able to tell you guys is they're b stock or blemish units..........I don't think so though.
https://www.thirdgen.org/forums/exha...ong-tubes.html
#57
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
My buddy had Hooker 2055's with the stock black paint. His header skin temps were around 1200*F. I had my 2055's coated inside AND out including the y-pipe with a 1700* inside and out coating. I will be using my buddies Temp gun to see the difference in temps with coated inside and out vs stock black paint (which is for protection and is not hi-temp). I was told skin temps should drop about 3))*F, which is a significant reduction in under hood temps.
Coating inside the header improves exhaust velocity I think it is, for better flow and more power, about .00001% more power, but its there
#58
Engine: 305TPI
evilstuie
04-14-2016 08:52 PM
