Exhaust manifold?!?!
Old Mar 27, 2010 | 12:32 PM
ben_cb7's Avatar
Car: 1982 Berlinetta
Engine: 360
Transmission: TH350
Axle/Gears: Stock
So i have an 1982 camaro with a 350 swap from a second gen z28. Recently I noticed an exhaust leak and realized there are screws on the back of the manifold and a couple of them came loose. First question is what the heck are those screws for?!? Second is there something I can do to plug the holes since the threads are messed up (welding it or something)? Third....I went to the local junkyard and looked for a replacement but didn't find anything close...so is there a stock replacement for the drivers side I can buy?
THANKS!
Old Mar 27, 2010 | 04:13 PM
ben_cb7's Avatar
Engine: 360
Transmission: TH350
Axle/Gears: Stock
Re: Exhaust manifold?!?!
this is what i need a replacement for....its a stock exhaust manifold for a second gen camaro 350. if you have one PM me!!! if u know where to get a cheap one PM me! THANKS
Old Mar 27, 2010 | 06:56 PM
carscomefirst's Avatar
Car: 04 gtp, 96 f150, 88 camaro
Engine: 3.8sc, 5.0, 385ci
Transmission: auto, 5speed, 700r4
that looks more like a third gen manifold to me.
try a dorman part #674-518. $85 at advance auto or im sure you could do a search and find it cheaper or closer to you.
Or dorman# 674-276 $109 at advance 2nd gen camaro w/ CA emissions
Old Mar 27, 2010 | 07:07 PM
Stephen's Avatar
Car: 87 GTA
Those holes look like where A.I.R. tubes go. 1/4" NPT pipe plugs will plug them right up.
Old Mar 27, 2010 | 11:18 PM
ben_cb7's Avatar
Engine: 360
Transmission: TH350
Axle/Gears: Stock
I am not familiar with A.I.R. and the plugs have basically broken off so cant plug them anymore... tried to JB weld but it melts at 600
Old Mar 27, 2010 | 11:21 PM
ben_cb7's Avatar
Engine: 360
Transmission: TH350
Axle/Gears: Stock
Thanks! thats what i was looking for...now to find a cheap price lol
Old Mar 27, 2010 | 11:26 PM
Stephen's Avatar
Car: 87 GTA
You could weld those holes shut, or tap new threads & get bigger plugs to fit those threads.
Cheaper than buying whole new parts.
Old Mar 27, 2010 | 11:31 PM
ben_cb7's Avatar
Engine: 360
Transmission: TH350
Axle/Gears: Stock
was going to try but i guess welding cast is hard....have to stick weld....
Old Mar 30, 2010 | 10:31 PM
Air_Adam's Avatar
Engine: 454ci, 6.1 Hemi
Transmission: TH350, A5
Braze them closed if the threads are all f**ked up.
Hotrodboba400
Dec 10, 2019 07:07 PM
gta892000
Aug 11, 2019 11:16 AM
db057
Apr 28, 2019 07:45 AM
86CamaroDan
Sep 29, 2015 10:08 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
