84 camaro with lt1 and t56, lowered, exhaust setup
Old Apr 14, 2010 | 08:28 PM
Eriks84ls1's Avatar
Car: 84 z28
Engine: lt1
Transmission: 4l60e
ok so as the title states i have an 84 camaro with a t56/lt1 combo and i will be lowering it, as of right now i have an slp y pipe on the stock lt1 manifolds that gives me i ground clearance issue. i want as much as possible ground clearance. so i was wanting to pool all you who have knowlage of the subject and ask if i get a full exhaust setup that bolts up to the org. motor and bring the tubes under the pass floor board and bring it to the center to run to the back. will i suffor in the flow department? will it bolt up to the tl1 heads ok?
Old Apr 14, 2010 | 09:00 PM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: 84 camaro with lt1 and t56, lowered, exhaust setup
LT1s dont have any different exhaust requirements than earlier small blocks do. Anything made to fit a thirdgen with a small block will fit. You have the right idea following the stock routing, it will give you the best clearance. Single 3" works for must guys, if you're going well north of 400hp then get a single 4" setup. for more info on that do a search, lots of guys on here have single 4" setups.
customblackbird
Aug 15, 2021 10:16 PM
1984HO
Mar 19, 2021 11:59 AM
Vintageracer
Jan 10, 2020 05:33 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
rsrmoore
Aug 7, 2015 08:44 PM
