Street rod style header fitment?
Old Apr 18, 2010 | 10:57 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Well I picked up my new 88 formula the other day. The headers are extremely warped and you can actually see a fireball in between the head and header flange.
They look like they were cheap summit/jegs/flowtech junk to begin with. I really want to drive my car ASAP, so I started hunting down some locally.
Only reasonable ones I've found were shorties for a chevy pickup and a generic "street rod" style header. I really want to get the street rod header, as it is stainless, brand new, 1 5/8 primaries and CHEAP for what it is.
Will these fit the car though? I can't help but wonder if anyone here has tried them out.
Old Apr 18, 2010 | 06:26 PM
87350IROC's Avatar
Car: 87' IROC
Re: Street rod style header fitment?
If they are the block-hugger style I really doubt they will fit. They will probably hit the k-member. You will notice third gen headers exit to the rear to clear the k-member, not straight down like block-huggers. The next problem with the block-huggers would be the y-pipe. How would you connect them to the rest of the exhaust?
Old Apr 18, 2010 | 06:39 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
To my knowledge - Pretty much the only headers that fit these cars are headers designed for them - after 5 years as a member here on TGO, I've never seen anyone with anything other than 82-92 F-Body designed headers.
Old Apr 19, 2010 | 02:04 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
thanks for the info. I figured as much, but couldn't hurt to ask just in case.
Anyone know how forgiving a very soft gasket is to warped headers?
Old Apr 19, 2010 | 08:21 AM
Car: 1992 RS
Engine: Carbed 350
I'd try an Earl's Dead Soft gasket - they are thick, almost 1/4", until you put them in and tighten the bolts, then they squish where they need to. They are soft aluminum or copper (I think either is available, I used aluminum), and they seal really well. Available off the shelf at AZ usually, about $40.
Old Apr 19, 2010 | 03:02 PM
Pocket's Avatar
Car: 91 Trans Am
Pretty good, but dont expect a miracle
A better solution would be to cut the flange in between the primaries so the tubes can flex on their own more and not pull away from the gasket. May not help if they're beyond hope, but its a free mod that may solve the issue
Old Apr 19, 2010 | 08:13 PM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
wow.... how did I not think of that....
I'll give it a try soon and post some results. Have to get some new header bolts first since these ones have seen better days.
I noticed that header bolts come in 3/4" and 1" lengths. I'm using a 70's head on my setup.. could it be possible the previous owner used 1" and they are bottoming out in the head? Because I cranked these things TIGHT as much as I felt the bolt head could take and there's still a pretty good gap there.
Old Apr 19, 2010 | 08:22 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
anything is possible. usually the 1" bolts are needed with headers with 3/8" flanges. he could be useing some crazy bolt thats even longer, pop one one and see whats up
I would just try cutting the flanged between the tubes and using new gaskets and bolts before buying headers.
and for what its worth, there was agut on here a little while back who put the block huggers on, he didnt have good pics, and couldnt describe anything worth a damn, but he had to do something with raising the engine mounts about 1" and some other crazy stuff to get them to work. So they are pretty much not worth your time.
Old Apr 19, 2010 | 09:36 PM
Pocket's Avatar
Car: 91 Trans Am
Use 3/4" bolts. If the head doesnt snug down, itll never seal
Old Apr 20, 2010 | 09:30 AM
Gordiggz's Avatar
Car: 1983 Z-28
Axle/Gears: ?
Sounds like a plan. I confirmed that the injectors are 24# fords. Can't wait to find out what cam is in it after this, I know it can't be the factory roller so it's probably something ridiculous for an efi motor on a stock tune.... exciting stuff.
Street Lethal
Apr 30, 2019 12:14 PM
Reborn756
Sep 4, 2015 03:42 AM
gixxer92
Sep 1, 2015 04:32 PM
lt1z350
Aug 28, 2015 05:57 AM
kah992
Aug 19, 2015 02:55 PM
