Best headers for 383 w/ AFR 1040s ?
Old Apr 21, 2010 | 01:45 AM
PowerHour84's Avatar
Car: 1984 Z28 Camaro
Engine: 305 -> 383 Stroker
Transmission: T5 -> T56
Axle/Gears: 3.73 Posi
Looking to find some headers for my 383. Its running a Victor Jr. and AFR 1040s. Ive heard of people having some issues with the port sizes, so if anyone could recommend some nice headers it would be greatly appreciated!
Old Apr 21, 2010 | 03:02 AM
darkhorse91's Avatar
Car: 91 B4C/91 RS 305
Engine: L98 and L03
Transmission: 2xTH700R4
Axle/Gears: 3.23 LSD/2.73 Open
Re: Best headers for 383 w/ AFR 1040s ?
i hear dyno don's 1-3/4 headers work great with a 383 and should work with the AFR heads. at least that is what was suggested to me
Old Apr 21, 2010 | 03:57 AM
Thanks dark i will give them a look
Old Apr 21, 2010 | 04:42 AM
Engine: L98 and L03
it's a member on this forum. He is reproducing the SLP 1-3/4 shorties since they stopped making them. from what I hear he does excellent work. top down solutions is selling them here not to mention they are a sponsor for this site. check it out
Old Apr 22, 2010 | 01:08 AM
thank you
Old May 2, 2010 | 11:18 AM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
Old May 2, 2010 | 03:19 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
The AFR heads have a slightly larger exhaust port than a standard SBC head. Don's headers will clear the AFR head exhaust port. I don't know of any other header for our cars that can make that claim. You do not want any exhaust restictions.
Old May 2, 2010 | 09:56 PM
radical82's Avatar
Car: '82 Camaro
Engine: 383
Transmission: TKO 5 speed
Axle/Gears: 31 spline 9" with 4.56:1
Step headers will actually help with the power, doing a set now for 1040 heads that come out of the flange at 1 3/4" then step to 1 7/8" with 32" tubes and a 3 1/2" collector... Engine isn't done yet, but it will get break in time and a few pulls on the dyno when it's finished.
Shroty headers are a step above the cast iron exhaust manifolds, but certainly not the hot setup for performance... Depends on what you need for headers, if it's a street car in Ca., I suppose the shorties with AIR tubes are probably about the best the law will allow...
Old May 3, 2010 | 11:14 AM
Dyno Don's Avatar
We have done dyno tests with both here in Ca., the difference isn't worth talking about.
Very minor gain in some areas.
Now if you are talking all out racing.....different story.
Old May 3, 2010 | 12:14 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Need a 1 3/4 port to effectively cover the AFR exhaust port. I've tested 1 5/8 hooker 2055's and hooker 2210 1 3/4 headers and the 1 3/4's clear the port. I've built my turbo manifolds with 1 3/4 rectangular ports and it cleared more than enough. Used Hooker prewelded stubs flanges for that setup.
Knowing what I know now after seeing some results of dyno don's headers versus longtubes, i'd go with his headers for best ground clearance. Longtubes dont offer the room for good exhaust clearance IF using an automatic transmission. T56 with right crossmember or maybe even a T5 tranny will allow some room to run the pipes between the frame rails along side the transmission. Autos do not have the room there and you must go under the frame rails. Leaves very little room.
Old May 8, 2010 | 05:28 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
Originally Posted by Dyno Don
What size collector is that? The SLP's are 2 1/4" OD. too small for me (383)
Old May 12, 2010 | 01:13 PM
joeblue83's Avatar
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
i run dyno dons shorty headers along with his y-pipe with my 383. Works great, and fits perfect. much better product than the slp's
Old May 13, 2010 | 08:40 PM
cam-ro's Avatar
hello ....i want info for my 383 with short header hooker .....is possible to install oil pan 6 qt or 7 qt ?? without modifying exaust, frame ..ect.... ....i want more oil QT . tank'S ....is possible = wich buy , moroso, proform .....my block one peace rear main seal ans clear for my stroke 7.50
Old May 13, 2010 | 10:35 PM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Transmission: TH400
shorty headers and y pipe should clear any oil pan for camaro/firebird. Most long tubes will clear most oil pans. I had Canton's road race 6qt pan with huge side kickouts and my long tubes cleared with ministarter.
I have canton's drag pan for my turbo car now and theres plenty of room for shorties and y pipe.
Old May 16, 2010 | 07:44 PM
VincentZ28's Avatar
Car: 1990 G92 IROC Z Miniram
Engine: 388cu 6.4 Liters
Transmission: G-Force T5
Axle/Gears: 3.73 Gears
Dyno Dons headers are 1 3/4 tubes with 2 1/2 collectors and depending on your application 2 1/2in for dual cats or 2 1/2in into 3in Y-Pipe for single cat.
Old May 16, 2010 | 08:32 PM
Jamesonpf5379's Avatar
Car: 1984 Camaro ZF
Engine: 383 stroker
Where would I able to get those?
Old May 16, 2010 | 08:47 PM
VincentZ28's Avatar
Send Dyno Don a private message an or goto the Southern Cali Board.
Old May 17, 2010 | 02:24 AM
MotorMouth's Avatar
Car: 1992 Camaro RS
Engine: 305 TBI
Here's a link to buy them. http://www.top-downsolutions.com/ind...49a3b3ad6e7e97
evilstuie
Feb 28, 2016 03:33 PM
LT1Formula
20
Nov 14, 2015 12:02 AM
Magman
Sep 12, 2015 10:43 PM
buckshot63
Sep 10, 2015 09:15 AM
gixxer92
Sep 1, 2015 04:32 PM
