My true duals
Old Apr 25, 2010 | 10:12 PM
ShMaCk2004's Avatar
Car: 1987 Camaro IROC-Z
Transmission: LS1 T56
Axle/Gears: Richmond 3.73
My true duals
I built a new exhaust for my 87 Camaro while doing an LS1 swap.
It is 2.5" pipe with an x-pipe and 2 power stick mufflers.
The pipes exit on the sides right in front of the rear tire.
Old Apr 26, 2010 | 08:22 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: My true duals
nice job, bet thats fun to drive with that ls1 and 6 speed ,jimmy
Old Jun 9, 2010 | 02:14 AM
ShMaCk2004's Avatar
Re: My true duals
yup its like music to my ears
Old Jun 11, 2010 | 10:39 AM
1MeanZ's Avatar
Car: 86 IROC
Engine: 383
Transmission: TKO 600
Axle/Gears: 3.54 Dana 44 IRS
Re: My true duals
#1 any reason you didnt use mandrel bends? Cash for a LS1 and T56 swap and then use autodump crimp bends?
#2 post a pic of the car on the ground and lets see how great your ground clearance is.
#3 your trans cross member looks interesting as well, might wanna beef that up.
Old Jun 11, 2010 | 03:38 PM
ShMaCk2004's Avatar
Re: My true duals
ran out of cash for mandrel bends after the LS1 swap. Ground clearance isn't to bad, it scrapes on high speed bumps but i'll get a pic when i figure out what i did with my camera lol.
The crossmember is from hawks so im sure it will be fine.
http://www.hawksthirdgenparts.com/tr...t566speed.aspx
Old Jun 11, 2010 | 09:27 PM
built91Z28's Avatar
Car: 1991 Camaro Z28
Engine: 357, Canfield heads, solid roller,
Transmission: Upgraded 03 Cobra T56
Axle/Gears: 9" 3.50 gears and Detroit Locker
Re: My true duals
What I would be concerned about is that it looks like the exhaust almost touches the rear control arms and the rear axle is on jackstands. That means when the rear drops down (or the body goes up) the control arm may hit the exhaust.
Old Jun 12, 2010 | 03:06 AM
ShMaCk2004's Avatar
Re: My true duals
hasn't happened yet
Old Jun 12, 2010 | 06:50 AM
pound's Avatar
Car: 1990 Firebird
Engine: 350 TBI
Axle/Gears: Auburn posi 3.73
Re: My true duals
Thats a nice looking setup. I bet its pretty loud with those mufflers. So what did you use to paint the pipes?
Old Jun 12, 2010 | 03:55 PM
ShMaCk2004's Avatar
Re: My true duals
its loud but i like it. i painted it with 500 degree engine paint but it burned off already so im going to spray it with some 2000 degree header paint and see how that holds up.
mattcanty
Oct 12, 2015 11:08 AM
paul_huryk
Oct 1, 2015 04:27 PM
