what is too big of an exhaust?
Old May 5, 2010 | 02:27 PM
91camarosRS's Avatar
Car: 02wrx/88 rs
Engine: 2.0L turbo/nothing yet!
Transmission: 4eat/waiting on a t56
im planning on building a high horse(550) lt1 im planning on using headman d port long tubes 1 5/8 primarys(i know a little small but affordable for now) dual 3 into a single 4inch to a spintech in back. now the queston is untill i do the swap, can i put that on my 305? and will those headers fit? just wondering
Old May 6, 2010 | 08:13 AM
94_LT1_Z's Avatar
Re: what is too big of an exhaust?
Yes you can put that on your 305. Might lose a little torque down low but it should work fine.
Old May 6, 2010 | 09:41 AM
Wadebryant's Avatar
Car: 87IROC, 740iBMW, 328iBMW, 86GMC
Engine: 5.7, 4.4LV8, 2.8, 6.0
Transmission: Manuals & Auto's
Axle/Gears: 3.27, 3.42
Unless this is a race only vehicle, 4" is too large. You'll loose the scavenge affects and subsequently low end, possibly mid range torque Will suffer.
Old May 6, 2010 | 10:23 AM
Orr89RocZ's Avatar
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
550hp will need 1210 cfm of flow. Single 4" flows 1440cfm at 28" of H20. I think its a good match. Dual 3's flow more like 1625 cfm total and would be abit large for a 550hp machine but not horrible. Dual 2.5's however flow 1130 cfm and would be a touch small.
Keep in mind with a single exhaust you need one muffler that will also flow as good as the straight pipe. Dynomax ultraflo rounds, bullets, magnaflow straight thru, borla straight thru, and other straight thrus should do it.
My street 383 loved single 4" exhaust. Sounded great too. No lack of power anywhere. I would estimate 500 crank hp based on 400whp thru the automatic trans but it may have been closer to 550. It was a strong motor.
My turbo car now has dual 3" on a 9 to 1 compression 401" motor. Mild hyd roller cam, and it has plenty of low end power when normally driving. Feels fine to me even with 2.73 gears and a loose converter which is close to 4200 stall. I dont think you can go too large on the exhaust that it would kill off a drastic amount of power.
Old May 6, 2010 | 10:55 AM
Car: 02wrx/88 rs
i know what you are sying. that set up(headers,dual 3, single 4) is for my 383. but untill i build it, to get it out of the way can i put it on my 305?
and i know that from research, that spintech is not the best flowing, i understand that BUT i got a deal from someone on here and i really want the sound that comes from them
Old May 6, 2010 | 10:56 AM
Car: 02wrx/88 rs
you think these will fit my 305? http://www.summitracing.com/parts/HED-68469/
Old May 6, 2010 | 10:59 AM
Car: 02wrx/88 rs
or on my 305 ill just put it in and somewhere ill neck it down to 2.5 and back up to 4
Old May 6, 2010 | 12:02 PM
84 z28's Avatar
Car: 1984 z28
Engine: 355
Axle/Gears: Moser 9" 4.11
Almost all SBC headers are the same & they will fit 305,350,383 etc. Yes they will fit your motor just dont get the cheap painted ones.
Old May 6, 2010 | 12:08 PM
Car: 02wrx/88 rs
well im talking about port type.
and i can only afford cheap paint now..... i might get them coated later. or buy 2210s
Old May 6, 2010 | 12:13 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
If do go with those long tubes check the clearances around the rear K-member and A-Arms. I had to take off a notch on driverside back mounting tab to get my Hooker super comps to fit. (there dented from previous owner not clearancing them on there car tho).
Old May 6, 2010 | 12:16 PM
Engine: 383 SBC
If you check under applications on the tab it shows what they will work with. They have 305s and 350 listed of course. Should work fine.
They may require a ministarter depending on how much room you have in there. I know I had to take the mini-starter off, install the passenger header then wrestle and install the starter again.
Old May 8, 2010 | 04:09 PM
383fbod's Avatar
Car: 88 IROC-Z
Engine: 383
Axle/Gears: 4th gen 3.42posi
what type of headers / ypipe did that street 383 have?
Old May 14, 2010 | 04:55 PM
Car: 02wrx/88 rs
now what happens to flow on the 3 inch if i oval them to clear subframe
Bubbajones_ya
Jul 6, 2024 08:32 PM
gta892000
Aug 11, 2019 11:16 AM
webeeZ28
Sep 14, 2015 12:00 PM
Djmathis123
Sep 8, 2015 08:42 PM
89fast5oh
Sep 8, 2015 09:55 AM
